Up to 20% off select tools
LG Cosmos 2 Option Buttons Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
88
All Time:
1,082
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Most of the LG Cosmos 2 must be disassembled prior to replacing the buttons. Follow these steps to complete this task.
    1. LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 1 of 3 LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 2 of 3 LG Cosmos 2 Option Buttons Replacement, Battery: step 1, image 3 of 3
      • Insert the plastic opener into the slot at the top of the device.
      • Apply gentle pressure with the plastic tool to pop the back case off.
      Ask FixBot
    2. LG Cosmos 2 Option Buttons Replacement: step 2, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 2, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 2, image 3 of 3
      • Use the plastic opener to lift, and remove, the device battery.
      Ask FixBot
    1. LG Cosmos 2 Option Buttons Replacement, Rear Case: step 3, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
      Ask FixBot
    2. LG Cosmos 2 Option Buttons Replacement: step 4, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 4, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 4, image 3 of 3
      • Use the plastic opener to pry the rear case loose.
      • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
      Ask FixBot
    1. LG Cosmos 2 Option Buttons Replacement, Motherboard: step 5, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
      Ask FixBot
    2. LG Cosmos 2 Option Buttons Replacement: step 6, image 1 of 1
      • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
      Ask FixBot
    3. LG Cosmos 2 Option Buttons Replacement: step 7, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 7, image 2 of 2
      • Use the plastic opener to disconnect the ribbon cable.
      Ask FixBot
    4. LG Cosmos 2 Option Buttons Replacement: step 8, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that attach the motherboard to the case.
      • Note: Pull on the cables gently to prevent damage for future use.
      Ask FixBot
    5. LG Cosmos 2 Option Buttons Replacement: step 9, image 1 of 1
      • Remove the motherboard from the front case.
      Ask FixBot
    1. LG Cosmos 2 Option Buttons Replacement, Option Buttons: step 10, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
      Ask FixBot
    2. LG Cosmos 2 Option Buttons Replacement: step 11, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 11, image 2 of 2
      • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
      Ask FixBot
    3. LG Cosmos 2 Option Buttons Replacement: step 12, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
      • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
      Ask FixBot
    4. LG Cosmos 2 Option Buttons Replacement: step 13, image 1 of 2 LG Cosmos 2 Option Buttons Replacement: step 13, image 2 of 2
      • Use the plastic opener to pry open the front of the phone.
      • Slip the ribbon cable through the slit to fully separate the two pieces.
      Ask FixBot
    5. LG Cosmos 2 Option Buttons Replacement: step 14, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
      Ask FixBot
    6. LG Cosmos 2 Option Buttons Replacement: step 15, image 1 of 1
      • Detach the ribbon cable with the plastic opener.
      Ask FixBot
    7. LG Cosmos 2 Option Buttons Replacement: step 16, image 1 of 3 LG Cosmos 2 Option Buttons Replacement: step 16, image 2 of 3 LG Cosmos 2 Option Buttons Replacement: step 16, image 3 of 3
      • Use the spudger to pry the metal piece loose.
      • Remove the metal piece along with the two ribbon cables.
      Ask FixBot
    8. LG Cosmos 2 Option Buttons Replacement: step 17, image 1 of 1
      • Flip the front of the phone over and the old option buttons will fall out.
      • Insert new option buttons.
      Ask FixBot
Author
with
Nick White
866 Reputation
8 Guides authored
Clemson, Team 13-1, Benson Fall 2013 Member of Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 88
All Time: 1,082
