Up to 20% off select tools
LG Cosmos 2 Front Keyboard Replacement
Views: 1.2K
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
84
All Time:
1,221
Comments: 2
2 comments on steps.
Completed: 0
Favorites: 0
Time Required: 30 - 45 minutes
Difficulty: Moderate
Inconsistent Images
Updating the images on this guide to be more consistent with the prerequisites would increase its awesomeness.
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LG Cosmos 2 Front Keyboard Replacement, Battery: step 1, image 1 of 3 LG Cosmos 2 Front Keyboard Replacement, Battery: step 1, image 2 of 3 LG Cosmos 2 Front Keyboard Replacement, Battery: step 1, image 3 of 3
      • Insert the plastic opener into the slot at the top of the device.
      • Apply gentle pressure with the plastic tool to pop the back case off.
      Ask FixBot
    2. LG Cosmos 2 Front Keyboard Replacement: step 2, image 1 of 3 LG Cosmos 2 Front Keyboard Replacement: step 2, image 2 of 3 LG Cosmos 2 Front Keyboard Replacement: step 2, image 3 of 3
      • Use the plastic opener to lift, and remove, the device battery.
      Ask FixBot
    1. LG Cosmos 2 Front Keyboard Replacement, Rear Case: step 3, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the six 2mm screws that are located along the edge of the rear case. Set the screws aside.
      Ask FixBot
    2. LG Cosmos 2 Front Keyboard Replacement: step 4, image 1 of 3 LG Cosmos 2 Front Keyboard Replacement: step 4, image 2 of 3 LG Cosmos 2 Front Keyboard Replacement: step 4, image 3 of 3
      • Use the plastic opener to pry the rear case loose.
      • This can be difficult. You will need to pry around the entire edge of the rear case, not just in one place.
      Ask FixBot
    1. LG Cosmos 2 Front Keyboard Replacement, Motherboard: step 5, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the two 3mm screws that attach the motherboard to the front case. Set the screws aside
      Ask FixBot
    2. LG Cosmos 2 Front Keyboard Replacement: step 6, image 1 of 1
      • Rotate the phone 180 degrees and use the plastic opener to lift the metal piece that covers the ribbon cable.
      Ask FixBot
    3. LG Cosmos 2 Front Keyboard Replacement: step 7, image 1 of 2 LG Cosmos 2 Front Keyboard Replacement: step 7, image 2 of 2
      • Use the plastic opener to disconnect the ribbon cable.
      Ask FixBot
    4. LG Cosmos 2 Front Keyboard Replacement: step 8, image 1 of 2 LG Cosmos 2 Front Keyboard Replacement: step 8, image 2 of 2
      Tool used on this step:
      Buy
      • Use tweezers to disconnect the two cables that attach the motherboard to the case.
      • Note: Pull on the cables gently to prevent damage for future use.
      Ask FixBot
    5. LG Cosmos 2 Front Keyboard Replacement: step 9, image 1 of 1
      • Remove the motherboard from the front case.
      Ask FixBot
    1. LG Cosmos 2 Front Keyboard Replacement, Option Buttons: step 10, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the four 1mm screws. Set the screws aside.
      Ask FixBot
    2. LG Cosmos 2 Front Keyboard Replacement: step 11, image 1 of 2 LG Cosmos 2 Front Keyboard Replacement: step 11, image 2 of 2
      • Pull the ribbon cable through the slit in the keyboard case to separate it from the sliding mechanism.
      Ask FixBot
    3. LG Cosmos 2 Front Keyboard Replacement: step 12, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the four 3mm screws. Set the screws aside.
      • Note: Two of the screws may be hidden underneath a black rubber film. Pull off this film if necessary.
      Ask FixBot
    4. LG Cosmos 2 Front Keyboard Replacement: step 13, image 1 of 2 LG Cosmos 2 Front Keyboard Replacement: step 13, image 2 of 2
      • Use the plastic opener to pry open the front of the phone.
      • Slip the ribbon cable through the slit to fully separate the two pieces.
      Ask FixBot
    5. LG Cosmos 2 Front Keyboard Replacement: step 14, image 1 of 1
      • Use a screwdriver and corresponding bit to remove the two 1mm screws. Set the screws aside.
      Ask FixBot
    6. LG Cosmos 2 Front Keyboard Replacement: step 15, image 1 of 1
      • Detach the ribbon cable with the plastic opener.
      Ask FixBot
    7. LG Cosmos 2 Front Keyboard Replacement: step 16, image 1 of 3 LG Cosmos 2 Front Keyboard Replacement: step 16, image 2 of 3 LG Cosmos 2 Front Keyboard Replacement: step 16, image 3 of 3
      • Use the spudger to pry the metal piece loose.
      • Remove the metal piece along with the two ribbon cables.
      Ask FixBot
    8. LG Cosmos 2 Front Keyboard Replacement: step 17, image 1 of 1
      • Flip the front of the phone over and the old option buttons will fall out.
      • Insert new option buttons.
      Ask FixBot
    1. LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: step 18, image 1 of 2 LG Cosmos 2 Front Keyboard Replacement, Front Keyboard: step 18, image 2 of 2
      • Use a tool to pry open the LCD display. Remove the display and the motherboard-looking device that it's connected to.
      Ask FixBot
    2. LG Cosmos 2 Front Keyboard Replacement: step 19, image 1 of 1
      • Rotate and remove the keypad from the front case.
      Ask FixBot
Author
with
Nick White
866 Reputation
8 Guides authored
Clemson, Team 13-1, Benson Fall 2013 Member of Clemson, Team 13-1, Benson Fall 2013
CLEM-BENSON-F13S13G1
3 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 84
All Time: 1,221
