LG CineBeam Speaker Replacement
  1. LG CineBeam Speaker Replacement, Bottom Plate: step 1, image 1 of 1
    • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
    Ask FixBot
  2. LG CineBeam Speaker Replacement: step 2, image 1 of 3 LG CineBeam Speaker Replacement: step 2, image 2 of 3 LG CineBeam Speaker Replacement: step 2, image 3 of 3
    • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
    Ask FixBot
  3. LG CineBeam Speaker Replacement, Motherboard: step 3, image 1 of 3 LG CineBeam Speaker Replacement, Motherboard: step 3, image 2 of 3 LG CineBeam Speaker Replacement, Motherboard: step 3, image 3 of 3
    • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
    • Repeat this process to remove the WiFi/Bluetooth card connector.
    • Remove the battery connector.
    • Remove the fan connectors.
    Ask FixBot
  4. LG CineBeam Speaker Replacement: step 4, image 1 of 2 LG CineBeam Speaker Replacement: step 4, image 2 of 2
    • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
    • Gently pull the ribbon cable out of the socket.
    • Repeat this process for the two display cables.
    Ask FixBot
  5. LG CineBeam Speaker Replacement: step 5, image 1 of 3 LG CineBeam Speaker Replacement: step 5, image 2 of 3 LG CineBeam Speaker Replacement: step 5, image 3 of 3
    • Lift the motherboard out of the casing.
    Ask FixBot
  6. LG CineBeam Speaker Replacement, Speaker: step 6, image 1 of 2 LG CineBeam Speaker Replacement, Speaker: step 6, image 2 of 2
    • Use your fingers to lift the speaker from the casing.
    Ask FixBot
Abid Neron
243 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 18
All Time: 301
