LG CineBeam Motherboard Replacement
    1. LG CineBeam Motherboard Replacement, Bottom Plate: step 1, image 1 of 1
      • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
      Ask FixBot
    2. LG CineBeam Motherboard Replacement: step 2, image 1 of 3 LG CineBeam Motherboard Replacement: step 2, image 2 of 3 LG CineBeam Motherboard Replacement: step 2, image 3 of 3
      • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
      Ask FixBot
    1. LG CineBeam Motherboard Replacement, Motherboard: step 3, image 1 of 3 LG CineBeam Motherboard Replacement, Motherboard: step 3, image 2 of 3 LG CineBeam Motherboard Replacement, Motherboard: step 3, image 3 of 3
      • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
      • Repeat this process to remove the WiFi/Bluetooth card connector.
      • Remove the battery connector.
      • Remove the fan connectors.
      Ask FixBot
    2. LG CineBeam Motherboard Replacement: step 4, image 1 of 2 LG CineBeam Motherboard Replacement: step 4, image 2 of 2
      • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
      • Gently pull the ribbon cable out of the socket.
      • Repeat this process for the two display cables.
      Ask FixBot
    3. LG CineBeam Motherboard Replacement: step 5, image 1 of 3 LG CineBeam Motherboard Replacement: step 5, image 2 of 3 LG CineBeam Motherboard Replacement: step 5, image 3 of 3
      • Lift the motherboard out of the casing.
      Ask FixBot
John Dalton
393 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 6
Past 30 Days: 47
All Time: 924
