Up to 20% off select tools
LG CineBeam Lens Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
2
Past 7 Days:
17
Past 30 Days:
86
All Time:
1,297
Comments: 1
1 comment on steps.
Completed: 0
Favorites: 0
Time Required: 25 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
The LG Cinebeam's (Model# PH150B) lens projects the image. If it is damaged or cracked, the image will be fuzzy or warped. This guide will help you replace the lens.
The lens is responsible for projecting the image. Before replacing it, inspect the lens carefully to see if any cracks are visible or any grease or dirt is piled up. It's a good idea to clean the lens with glass cleaner and check if the image is still unclear before replacing it.
Since the lens is made of glass, it is possible to crack or break, so use caution while removing it and putting in a new one.
You will have to remove the motherboard to access the lens. While removing it, make sure to use caution while replacing the ribbon cables as they could rip.
Before beginning, make sure to power off the projector completely and disconnect from any external power source.
    1. LG CineBeam Lens Replacement, Bottom Plate: step 1, image 1 of 1
      • Remove three 6 mm screws on the bottom plate with a Phillips #00 screwdriver.
      Ask FixBot
    2. LG CineBeam Lens Replacement: step 2, image 1 of 3 LG CineBeam Lens Replacement: step 2, image 2 of 3 LG CineBeam Lens Replacement: step 2, image 3 of 3
      • Using an iFixit opening tool, pry the bottom plate off of the device and remove it fully.
      Ask FixBot
    1. LG CineBeam Lens Replacement, Motherboard: step 3, image 1 of 3 LG CineBeam Lens Replacement, Motherboard: step 3, image 2 of 3 LG CineBeam Lens Replacement, Motherboard: step 3, image 3 of 3
      • Using an iFixit opening tool, press down the lever on the top of the minilock connector for the speaker and pull the plug out gently.
      • Repeat this process to remove the WiFi/Bluetooth card connector.
      • Remove the battery connector.
      • Remove the fan connectors.
      Ask FixBot
    2. LG CineBeam Lens Replacement: step 4, image 1 of 2 LG CineBeam Lens Replacement: step 4, image 2 of 2
      • Using an iFixit opening tool, pry up the black plastic tabs on the back of the power button/joystick board cable.
      • Gently pull the ribbon cable out of the socket.
      • Repeat this process for the two display cables.
      Ask FixBot
    3. LG CineBeam Lens Replacement: step 5, image 1 of 3 LG CineBeam Lens Replacement: step 5, image 2 of 3 LG CineBeam Lens Replacement: step 5, image 3 of 3
      • Lift the motherboard out of the casing.
      Ask FixBot
    1. LG CineBeam Lens Replacement, Speaker: step 6, image 1 of 2 LG CineBeam Lens Replacement, Speaker: step 6, image 2 of 2
      • Use your fingers to lift the speaker from the casing.
      Ask FixBot
    1. LG CineBeam Lens Replacement, Lens: step 7, image 1 of 3 LG CineBeam Lens Replacement, Lens: step 7, image 2 of 3 LG CineBeam Lens Replacement, Lens: step 7, image 3 of 3
      • Turn the device over so the power button is facing up.
      • Using an iFixit opening tool, pry open the top of the plastic casing and remove it completely.
      Ask FixBot
    2. LG CineBeam Lens Replacement: step 8, image 1 of 2 LG CineBeam Lens Replacement: step 8, image 2 of 2
      • Remove the three 6 mm screws holding the lens and LCoS assembly in place using a Phillips #00 screwdriver.
      • Remove the lens and LCoS assembly from the casing.
      Ask FixBot
    3. LG CineBeam Lens Replacement: step 9, image 1 of 3 LG CineBeam Lens Replacement: step 9, image 2 of 3 LG CineBeam Lens Replacement: step 9, image 3 of 3
      • Remove the 4 mm screws using a Phillips #00 screwdriver.
      • Pull the lens assembly off of the display assembly.
      • When putting in a new lens assembly, make sure the focus knob is on the correct side.
      Ask FixBot
Author
with
Abid Neron
243 Reputation
2 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 17
Past 30 Days: 86
All Time: 1,297
