LG Chocolate Motherboard Replacement
    1. LG Chocolate Motherboard Replacement, Battery: step 1, image 1 of 2 LG Chocolate Motherboard Replacement, Battery: step 1, image 2 of 2
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      Ask FixBot
    1. LG Chocolate Motherboard Replacement, Back Cover: step 2, image 1 of 1
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      Ask FixBot
    2. LG Chocolate Motherboard Replacement: step 3, image 1 of 3 LG Chocolate Motherboard Replacement: step 3, image 2 of 3 LG Chocolate Motherboard Replacement: step 3, image 3 of 3
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      Ask FixBot
    1. LG Chocolate Motherboard Replacement, Motherboard: step 4, image 1 of 2 LG Chocolate Motherboard Replacement, Motherboard: step 4, image 2 of 2
      • Carefully pry the motherboard off of the back case
      Ask FixBot
Maci Miri
39 Reputation
3 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
132 Guides authored
1 Guide Comment
is there any way to get information off of a motherboard with a chargeport that is broken?
Robert Gietzen - Reply Share
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 19
All Time: 1,228
