Up to 20% off select tools
LG Chocolate Keypad Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
22
All Time:
785
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: No estimate
Difficulty: Difficult
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LG Chocolate Keypad Replacement, Battery: step 1, image 1 of 2 LG Chocolate Keypad Replacement, Battery: step 1, image 2 of 2
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      Ask FixBot
    1. LG Chocolate Keypad Replacement, Back Cover: step 2, image 1 of 1
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      Ask FixBot
    2. LG Chocolate Keypad Replacement: step 3, image 1 of 3 LG Chocolate Keypad Replacement: step 3, image 2 of 3 LG Chocolate Keypad Replacement: step 3, image 3 of 3
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      Ask FixBot
    1. LG Chocolate Keypad Replacement, Sliding Front: step 4, image 1 of 1
      • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
      Ask FixBot
    2. LG Chocolate Keypad Replacement: step 5, image 1 of 2 LG Chocolate Keypad Replacement: step 5, image 2 of 2
      • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
      Ask FixBot
    3. LG Chocolate Keypad Replacement: step 6, image 1 of 2 LG Chocolate Keypad Replacement: step 6, image 2 of 2
      • Pry off the plastic tabs that cover two screws, as shown in the first picture.
      • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
      Ask FixBot
    4. LG Chocolate Keypad Replacement: step 7, image 1 of 1
      • Pry off the back cover from the front of the case using a plastic opening tool.
      Ask FixBot
    1. LG Chocolate Keypad Replacement, LCD Board: step 8, image 1 of 3 LG Chocolate Keypad Replacement, LCD Board: step 8, image 2 of 3 LG Chocolate Keypad Replacement, LCD Board: step 8, image 3 of 3
      • Pry the front speaker and wireless receiver out of the front case using a spudger.
      • They may be taped into the case, so don't be afraid to pry hard.
      Ask FixBot
    2. LG Chocolate Keypad Replacement: step 9, image 1 of 2 LG Chocolate Keypad Replacement: step 9, image 2 of 2
      • Starting with the side that has the speaker and receiver, carefully lift the LCD Board out of the case.
      Ask FixBot
    3. LG Chocolate Keypad Replacement: step 10, image 1 of 1
      • Unhook the ribbon cable using that flat side of a spudger.
      Ask FixBot
    4. LG Chocolate Keypad Replacement: step 11, image 1 of 1
      • Next, carefully remove the tape from the LCD board.
      Ask FixBot
    5. LG Chocolate Keypad Replacement: step 12, image 1 of 2 LG Chocolate Keypad Replacement: step 12, image 2 of 2
      • Finally, flip up the black switch to unhook the LCD screen from the LCD board using a spudger.
      • The LCD Board in now accessible.
      Ask FixBot
    1. LG Chocolate Keypad Replacement, LCD Screen: step 13, image 1 of 1
      • The LCD screen is no longer connected to the LCD board.
      Ask FixBot
    1. LG Chocolate Keypad Replacement, Keypad: step 14, image 1 of 1
      • Push the keypad out from the front of the phone and remove it.
      Ask FixBot
Author
with
Maci Miri
39 Reputation
3 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 22
All Time: 785
