Up to 20% off select tools
LG Chocolate Camera Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
91
All Time:
899
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LG Chocolate Camera Replacement, Battery: step 1, image 1 of 2 LG Chocolate Camera Replacement, Battery: step 1, image 2 of 2
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      Ask FixBot
    1. LG Chocolate Camera Replacement, Back Cover: step 2, image 1 of 1
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      Ask FixBot
    2. LG Chocolate Camera Replacement: step 3, image 1 of 3 LG Chocolate Camera Replacement: step 3, image 2 of 3 LG Chocolate Camera Replacement: step 3, image 3 of 3
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      Ask FixBot
    1. LG Chocolate Camera Replacement, Sliding Front: step 4, image 1 of 1
      • Unscrew the 4 Phillips 00 screws that connect the two halves of the phone together.
      Ask FixBot
    2. LG Chocolate Camera Replacement: step 5, image 1 of 2 LG Chocolate Camera Replacement: step 5, image 2 of 2
      • Between the two halves is a ribbon. Use a plastic opening tool to flip up the lock and disconnect it.
      Ask FixBot
    3. LG Chocolate Camera Replacement: step 6, image 1 of 2 LG Chocolate Camera Replacement: step 6, image 2 of 2
      • Pry off the plastic tabs that cover two screws, as shown in the first picture.
      • Then, remove the 6 Phillips 00 screws from the back of the case, as shown in the second picture.
      Ask FixBot
    4. LG Chocolate Camera Replacement: step 7, image 1 of 1
      • Pry off the back cover from the front of the case using a plastic opening tool.
      Ask FixBot
    1. LG Chocolate Camera Replacement, Camera: step 8, image 1 of 1
      • Carefully pry the connecting cable between the camera and the motherboard off of the board.
      Ask FixBot
    2. LG Chocolate Camera Replacement: step 9, image 1 of 2 LG Chocolate Camera Replacement: step 9, image 2 of 2
      • Using a small screwdriver, carefully pry the camera out of its position.
      • The camera will seem stuck to the board because of its tape. Don't be afraid to pry it.
      Ask FixBot
Author
with
Thomas
91 Reputation
4 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 91
All Time: 899
