Up to 20% off select tools
LG Chocolate Back Cover Replacement
Views: 1.1K
View statistics:
Past 24 Hours:
5
Past 7 Days:
20
Past 30 Days:
91
All Time:
1,094
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
The LG Chocolate VX 8500
You will learn how to replace the back cover of an LG Chocolate
The back cover of the LG chocolate helps the battery stay in place, and without the back cover the battery can potentially fall out which can create a whole separate problem.
If your device haves a swollen battery or its showing symptoms of a swollen battery make sure you don’t put it on the charger.
    1. LG Chocolate Back Cover Replacement, Battery: step 1, image 1 of 2 LG Chocolate Back Cover Replacement, Battery: step 1, image 2 of 2
      • Find a sliding button on the lower back side of the device and with your finger, slide it to the left firmly.
      • The battery should pop out fairly easily. If not, slide the button further or grab and pull it while sliding the button.
      Ask FixBot
    1. LG Chocolate Back Cover Replacement, Back Cover: step 2, image 1 of 1
      • You will need to use a Phillips #00 screwdriver.
      • Remove the four screws located at the corners beneath the battery.
      • Detach the back case from the phone.
      Ask FixBot
    2. LG Chocolate Back Cover Replacement: step 3, image 1 of 3 LG Chocolate Back Cover Replacement: step 3, image 2 of 3 LG Chocolate Back Cover Replacement: step 3, image 3 of 3
      • Take the case off by using a plastic opening tool.
      • Continue using the plastic opening tool around the sides of the device.
      • Unhook the eight tabs securing the back cover to the rest of the phone as seen in the second photo.
      • The back speaker will be connected to the motherboard.
      • This must be disconnected in order to remove the case.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Forrest Lipske
49 Reputation
2 Guides authored
Cal Poly, Team 19-46, Regan Winter 2013 Member of Cal Poly, Team 19-46, Regan Winter 2013
CPSU-REGAN-W13S19G46
4 Members
132 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 20
Past 30 Days: 91
All Time: 1,094
