LG Chocolate 3 Motherboard Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
33
All Time:
860
Comments: 0
Go to guide comments
Completed: 0
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 1 hour
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Introduction
Go to step 1 ↓
Use this guide to replace the motherboard of the LG Chocolate 3. Be prepared to handle small screws and delicate electronic connections. Be sure to pay attention to what shouldn't be disconnected. Some parts may be viable to fall out during this process; it is important to reassemble them during the motherboard replacement process.
Tools
    1. LG Chocolate 3 Motherboard Replacement, Battery: step 1, image 1 of 1
      • Turn the phone off before starting the replacement process.
      • Place the phone face down.
      • Press your finger down on the indentation and slide the back plate off.
      Ask FixBot
    2. LG Chocolate 3 Motherboard Replacement: step 2, image 1 of 3 LG Chocolate 3 Motherboard Replacement: step 2, image 2 of 3 LG Chocolate 3 Motherboard Replacement: step 2, image 3 of 3
      • Using your index finger lift and remove the battery from the phone.
      Ask FixBot
    1. LG Chocolate 3 Motherboard Replacement, Rear Case: step 3, image 1 of 1
      • Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
      • If needed, use the tip of a push pin instead of the spudger to remove the plastic inserts.
      Ask FixBot
    2. LG Chocolate 3 Motherboard Replacement: step 4, image 1 of 1
      Tool used on this step:
      Buy
      • Using a Phillips #00 screwdriver, remove the six 3mm long screws found along the edges of the phone.
      • If needed, use tweezers to remove loose screws from the recessed holes.
      • Screws are small, therefore, they should be placed in a secure location to prevent misplacement.
      Ask FixBot
    3. LG Chocolate 3 Motherboard Replacement: step 5, image 1 of 2 LG Chocolate 3 Motherboard Replacement: step 5, image 2 of 2
      • Pull the rear case up using the spudger.
      • The rear case is connected to the right side of the phone via red and blue cables, be careful not to pull these cables out.
      • The volume control buttons on the side might fall out of their sockets. Carefully replace them with a pair of tweezers before you reassemble the rear case.
      Ask FixBot
    4. LG Chocolate 3 Motherboard Replacement: step 6, image 1 of 1
      • Use tweezers to pull the clear end of the red and blue speaker cables away from motherboard.
      Ask FixBot
    5. LG Chocolate 3 Motherboard Replacement: step 7, image 1 of 2 LG Chocolate 3 Motherboard Replacement: step 7, image 2 of 2
      • Carefully remove the rear case from the phone.
      Ask FixBot
    1. LG Chocolate 3 Motherboard Replacement, Side Buttons: step 8, image 1 of 1
      Buy
      • Use tweezers to remove the music button found on the side of the phone.
      Ask FixBot
    2. LG Chocolate 3 Motherboard Replacement: step 9, image 1 of 2 LG Chocolate 3 Motherboard Replacement: step 9, image 2 of 2
      • Use tweezers to remove the volume control buttons on the opposite side of the phone.
      Ask FixBot
    1. LG Chocolate 3 Motherboard Replacement, Motherboard: step 10, image 1 of 1
      • Use the flat end of the spudger to lift the orange display data cable.
      Ask FixBot
    2. LG Chocolate 3 Motherboard Replacement: step 11, image 1 of 2 LG Chocolate 3 Motherboard Replacement: step 11, image 2 of 2
      • Carefully insert the plastic opening tool between the motherboard and the back of the phone.
      Ask FixBot
    3. LG Chocolate 3 Motherboard Replacement: step 12, image 1 of 2 LG Chocolate 3 Motherboard Replacement: step 12, image 2 of 2
      • Use your thumb and index finger to carefully lift and separate the motherboard from the back of the phone.
      • Be cautious of the orange display data cable, it may stick to the motherboard.
      • To avoid this, lift the data cable away from the motherboard before removal.
      Ask FixBot
Brenna Yagade
40 Reputation
6 Guides authored
Cal Poly, Team 12-35, Amido Spring 2013 Member of Cal Poly, Team 12-35, Amido Spring 2013
CPSU-AMIDO-S13S12G35
5 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 33
All Time: 860
