Tools
Spudger4.9
Introduction
Go to step 1 ↓If your LG Chocolate 3 keyboard is broken or malfunctioning, this guide will assist you in replacing the keypad. A keypad can be damaged from frequent use and become unresponsive. To access the keyboard, you will remove the battery, the rear case, the side buttons, and the motherboard. This is a complex repair with many small parts, and the process will take about an hour to complete. If you wish to reassemble the phone after the keypad replacement, follow the steps in reverse order.
Place the phone face down.
Press your finger down on the indentation and slide the back plate off.
Use the pointed end of the spudger to pull out the plastic inserts that are located on the left and right-hand corners.
Tool used on this step:Tweezers$4.99
Use tweezers to remove the music button found on the side of the phone.
To reassemble this device, follow these instructions in reverse order.
