LG CU515 Speaker Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
7
Past 30 Days:
43
All Time:
816
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Introduction
Go to step 1 ↓
Restore sound to your phone by replacng the speaker.
Tools
    1. LG CU515 Speaker Replacement, Battery: step 1, image 1 of 2 LG CU515 Speaker Replacement, Battery: step 1, image 2 of 2
      • Use your thumb to press down and slide off the back cover of the phone.
      Ask FixBot
    2. LG CU515 Speaker Replacement: step 2, image 1 of 3 LG CU515 Speaker Replacement: step 2, image 2 of 3 LG CU515 Speaker Replacement: step 2, image 3 of 3
      • Take out the battery by levering it out towards the bottom of the phone.
      Ask FixBot
    1. LG CU515 Speaker Replacement, Motherboard: step 3, image 1 of 1
      • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
      Ask FixBot
    2. LG CU515 Speaker Replacement: step 4, image 1 of 1
      • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
      Ask FixBot
    3. LG CU515 Speaker Replacement: step 5, image 1 of 3 LG CU515 Speaker Replacement: step 5, image 2 of 3 LG CU515 Speaker Replacement: step 5, image 3 of 3
      • Push the spudger into the crack separating the two pieces of the phone.
      • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
      • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
      • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
      Ask FixBot
    4. LG CU515 Speaker Replacement: step 6, image 1 of 1
      • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
      Ask FixBot
    5. LG CU515 Speaker Replacement: step 7, image 1 of 1
      • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
      Ask FixBot
    6. LG CU515 Speaker Replacement: step 8, image 1 of 1
      • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
      • Replace the motherboard with a new one.
      Ask FixBot
    1. LG CU515 Speaker Replacement, Speaker: step 9, image 1 of 2 LG CU515 Speaker Replacement, Speaker: step 9, image 2 of 2
      • Remove the speaker component from the back of the phone by lifting up the top part to a 45 degree angle and pulling it out.
      Ask FixBot
    2. LG CU515 Speaker Replacement: step 10, image 1 of 1
      • Pull speaker out of the component by grabbing the wire attached to it in order to replace it.
      Ask FixBot
Zack Mintzer
1 Reputation
6 Guides authored
Cal Poly, Team 21-55, Johann Spring 2013 Member of Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 7
Past 30 Days: 43
All Time: 816
