Student In Progress
This guide is being worked on by hardworking students.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Spudger4.9
Introduction
Go to step 1 ↓This guide will show you how to remove the Motherboard on your LF CU515 cell phone.
The Motherboard on a cell phone is responsible for core functions of the phone, and if it gets damaged, it can impact the function of your cell phone. A damaged motherboard could cause the phone to not hold a charge even if the battery is holding a charge, or cause the phone to get stuck in an endless cycle of turning on and off again. Sometimes water damage can cause this, or dropping the phone repeatedly.
This guide will require a lot of prying and unplugging of very small wires and other components that might seem precarious at first, but this guide will show you how to safely disconnect several pieces without damaging anything.
Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
Push the spudger into the crack separating the two pieces of the phone.
Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
