Up to 20% off select tools
LG CU515 Keypad Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
16
All Time:
637
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 20 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Replace the keypad for a new one.
    1. LG CU515 Keypad Replacement, Battery: step 1, image 1 of 2 LG CU515 Keypad Replacement, Battery: step 1, image 2 of 2
      • Use your thumb to press down and slide off the back cover of the phone.
      Ask FixBot
    2. LG CU515 Keypad Replacement: step 2, image 1 of 3 LG CU515 Keypad Replacement: step 2, image 2 of 3 LG CU515 Keypad Replacement: step 2, image 3 of 3
      • Take out the battery by levering it out towards the bottom of the phone.
      Ask FixBot
    1. LG CU515 Keypad Replacement, Motherboard: step 3, image 1 of 1
      • Push the spudger between each of the two rubber cushions and the body of the phone. Then turn the spudger to pop each cushion out.
      Ask FixBot
    2. LG CU515 Keypad Replacement: step 4, image 1 of 1
      • Remove six 3.0 mm Phillips #00 screws from the back of the phone.
      Ask FixBot
    3. LG CU515 Keypad Replacement: step 5, image 1 of 3 LG CU515 Keypad Replacement: step 5, image 2 of 3 LG CU515 Keypad Replacement: step 5, image 3 of 3
      • Push the spudger into the crack separating the two pieces of the phone.
      • Then use the plastic opening tools to pry the back off by separating the two pieces of the phone.
      • Repeat as necessary around the perimeter of the phone until the casing pops off. Use force as necessary without breaking the cover.
      • The back is attached to the motherboard by a wire, so don't pull the back casing off just yet.
      Ask FixBot
    4. LG CU515 Keypad Replacement: step 6, image 1 of 1
      • Gently pull the wire up from the motherboard, separating the back of the phone and the motherboard.
      Ask FixBot
    5. LG CU515 Keypad Replacement: step 7, image 1 of 1
      • Remove the plastic tab connecting the screen to the motherboard by pulling the tab up from the board.
      Ask FixBot
    6. LG CU515 Keypad Replacement: step 8, image 1 of 1
      • Gently grasp one of the corners of the motherboard and simply lift it straight up out of the phone casing.
      • Replace the motherboard with a new one.
      Ask FixBot
    1. LG CU515 Keypad Replacement, Keypad: step 9, image 1 of 1
      • Push keypad up and out of the phone casing until they separate.
      • Replace with new keypad.
      Ask FixBot
Author
with
Zack Mintzer
1 Reputation
6 Guides authored
Cal Poly, Team 21-55, Johann Spring 2013 Member of Cal Poly, Team 21-55, Johann Spring 2013
CPSU-JOHANN-S13S21G55
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 16
All Time: 637
