Up to 20% off select tools
LG CG225 Keyboard Replacement
View statistics:
Past 24 Hours:
0
Past 7 Days:
Past 30 Days:
24
All Time:
708
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 15 - 25 minutes
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Tools
Introduction
Go to step 1 ↓
Use this guide to replace the keyboard of the LG CG225.
    1. LG CG225 Keyboard Replacement, Rear Cover: step 1, image 1 of 1
      • Using a spudger or plastic opening tool, pry off the screw cover near the phone's antenna.
      Ask FixBot
    2. LG CG225 Keyboard Replacement: step 2, image 1 of 1
      • Remove a single Phillips #00 screw from beneath the cover.
      Ask FixBot
    3. LG CG225 Keyboard Replacement: step 3, image 1 of 1
      • Starting at the seam near the antenna, use a plastic opening tool to gently pry the back plate from the phone.
      Ask FixBot
    1. LG CG225 Keyboard Replacement, Motherboard: step 4, image 1 of 1
      • Carefully disconnect the gold ribbon cable from the upper right corner of the motherboard.
      Ask FixBot
    2. LG CG225 Keyboard Replacement: step 5, image 1 of 1
      • Using a small plastic opening tool, remove the motherboard.
      Ask FixBot
    1. LG CG225 Keyboard Replacement, Keyboard: step 6, image 1 of 1
      • Using your fingers, remove the plastic keyboard.
      • Loose buttons will sometimes fall off of the keyboard when it is removed.
      Ask FixBot
Author
with
Mackenzie
1 Reputation
2 Guides authored
Ohio State, Team 1-3, Meza Spring 2014 Member of Ohio State, Team 1-3, Meza Spring 2014
OSU-MEZA-S14S1G3
4 Members
24 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 24
All Time: 708
