Up to 20% off select tools
LG CG180 Keypad Replacement
Views: 1.8K
View statistics:
Past 24 Hours:
0
Past 7 Days:
2
Past 30 Days:
15
All Time:
1,798
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
How to remove the keypad from an LG CG180 cell phone.
    1. LG CG180 Keypad Replacement, Battery: step 1, image 1 of 1
      • Power down the cell phone by pressing and holding down the red "end call" button.
      Ask FixBot
    2. LG CG180 Keypad Replacement: step 2, image 1 of 1
      • Turn the phone screen-down so you are looking at the back cover.
      Ask FixBot
    3. LG CG180 Keypad Replacement: step 3, image 1 of 2 LG CG180 Keypad Replacement: step 3, image 2 of 2
      • Slide the back cover down using your finger to remove the cover from the phone.
      Ask FixBot
    4. LG CG180 Keypad Replacement: step 4, image 1 of 1
      • Place your finger at the top of the battery in small gap.
      Ask FixBot
    5. LG CG180 Keypad Replacement: step 5, image 1 of 1
      • Press downward while pulling outward to remove the battery.
      Ask FixBot
    1. LG CG180 Keypad Replacement, Hardshell Case: step 6, image 1 of 1
      • Remove all four screws on the back of the phone using a Phillips #00 screwdriver.
      Ask FixBot
    2. LG CG180 Keypad Replacement: step 7, image 1 of 1
      • Insert a plastic opening tool in the seam.
      Ask FixBot
    3. LG CG180 Keypad Replacement: step 8, image 1 of 2 LG CG180 Keypad Replacement: step 8, image 2 of 2
      • Run the tool along the seam to release all the tabs.
      Ask FixBot
    4. LG CG180 Keypad Replacement: step 9, image 1 of 2 LG CG180 Keypad Replacement: step 9, image 2 of 2
      • Pull the phone back cover off once all the tabs are released.
      Ask FixBot
    5. LG CG180 Keypad Replacement: step 10, image 1 of 1
      • Push the contents of the phone away from the hardshell case by applying pressure to the keypad with both thumbs.
      Ask FixBot
    6. LG CG180 Keypad Replacement: step 11, image 1 of 1
      • The hardshell case is separated from the rest of the phone.
      Ask FixBot
    1. LG CG180 Keypad Replacement, Keypad: step 12, image 1 of 2 LG CG180 Keypad Replacement, Keypad: step 12, image 2 of 2
      • Separate keypad from circuit board by turning it upside down and allowing it to fall off.
      Ask FixBot
Author
with
Alex Jacobs
17 Reputation
4 Guides authored
Cal Poly, Team 14-42, Regan Winter 2010 Member of Cal Poly, Team 14-42, Regan Winter 2010
CPSU-REGAN-W10S14G42
4 Members
60 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 2
Past 30 Days: 15
All Time: 1,798
