LG CF360 Motherboard Replacement
    1. LG CF360 Motherboard Replacement, Battery: step 1, image 1 of 2 LG CF360 Motherboard Replacement, Battery: step 1, image 2 of 2
      • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
      Ask FixBot
    2. LG CF360 Motherboard Replacement: step 2, image 1 of 1
      • Lift and remove the battery.
      Ask FixBot
    1. LG CF360 Motherboard Replacement, Back Cover: step 3, image 1 of 2 LG CF360 Motherboard Replacement, Back Cover: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two screw covers at the top of phone with tweezers.
      Ask FixBot
    2. LG CF360 Motherboard Replacement: step 4, image 1 of 1
      • Remove the six Phillips #000 (3mm) screws.
      Ask FixBot
    3. LG CF360 Motherboard Replacement: step 5, image 1 of 3 LG CF360 Motherboard Replacement: step 5, image 2 of 3 LG CF360 Motherboard Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
      • The plastic side buttons fall out when you take the back cover off.
      • The back cover is connected to the speaker by red and black wires.
      Ask FixBot
    4. LG CF360 Motherboard Replacement: step 6, image 1 of 1
      • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
      • Set the back cover with the speaker aside.
      Ask FixBot
    1. LG CF360 Motherboard Replacement, Motherboard: step 7, image 1 of 2 LG CF360 Motherboard Replacement, Motherboard: step 7, image 2 of 2
      • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
      • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
      Ask FixBot
    2. LG CF360 Motherboard Replacement: step 8, image 1 of 1
      • Gently remove the blue transparent tape from the connector.
      Ask FixBot
    3. LG CF360 Motherboard Replacement: step 9, image 1 of 1
      • With the plastic opening tool, gently pry the LCD connector from the motherboard.
      • Set the motherboard aside.
      Ask FixBot
3 other people completed this guide.
Aaron
167 Reputation
1 Guide authored
Cal Poly, Team 4-27, Amido Fall 2013 Member of Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 116
All Time: 1,475
