LG CF360 Front Speaker Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
31
Past 30 Days:
97
All Time:
855
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 3
3 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 45 minutes - 1 hour
Difficulty: Difficult
Introduction
Go to step 1 ↓
Replacing the speaker requires soldering and extensive disassembly. Refer to iFixit's soldering guide if you have never used a soldering iron or if you need a refresher.
Tools
    1. LG CF360 Front Speaker Replacement, Battery: step 1, image 1 of 2 LG CF360 Front Speaker Replacement, Battery: step 1, image 2 of 2
      • On the back of the phone, place your thumb on the three raised bumps and slide the back cover upward.
      Ask FixBot
    2. LG CF360 Front Speaker Replacement: step 2, image 1 of 1
      • Lift and remove the battery.
      Ask FixBot
    1. LG CF360 Front Speaker Replacement, Back Cover: step 3, image 1 of 2 LG CF360 Front Speaker Replacement, Back Cover: step 3, image 2 of 2
      Tool used on this step:
      Buy
      • Remove the two screw covers at the top of phone with tweezers.
      Ask FixBot
    2. LG CF360 Front Speaker Replacement: step 4, image 1 of 1
      • Remove the six Phillips #000 (3mm) screws.
      Ask FixBot
    3. LG CF360 Front Speaker Replacement: step 5, image 1 of 3 LG CF360 Front Speaker Replacement: step 5, image 2 of 3 LG CF360 Front Speaker Replacement: step 5, image 3 of 3
      • Use the plastic opening tool to pry the back cover off. Insert the tool between the back cover and red mid section and go around the entire phone.
      • The plastic side buttons fall out when you take the back cover off.
      • The back cover is connected to the speaker by red and black wires.
      Ask FixBot
    4. LG CF360 Front Speaker Replacement: step 6, image 1 of 1
      • Use the tweezers to remove the red and black wires connecting the speaker to the green motherboard by pinching the sides of the plastic base near the motherboard.
      • Set the back cover with the speaker aside.
      Ask FixBot
    1. LG CF360 Front Speaker Replacement, Motherboard: step 7, image 1 of 2 LG CF360 Front Speaker Replacement, Motherboard: step 7, image 2 of 2
      • Use the plastic opening tool to gently lift the snapped-in motherboard from the front panel.
      • An orange ribbon from the LCD is connected to the underside of the motherboard, so do not force the motherboard from the rest of the phone yet.
      Ask FixBot
    2. LG CF360 Front Speaker Replacement: step 8, image 1 of 1
      • Gently remove the blue transparent tape from the connector.
      Ask FixBot
    3. LG CF360 Front Speaker Replacement: step 9, image 1 of 1
      • With the plastic opening tool, gently pry the LCD connector from the motherboard.
      • Set the motherboard aside.
      Ask FixBot
    1. LG CF360 Front Speaker Replacement, Front Case: step 10, image 1 of 1
      • Take the front case and unscrew the four Phillips #000 (1mm) screws around the ribbon.
      Ask FixBot
    2. LG CF360 Front Speaker Replacement: step 11, image 1 of 1
      • Gently pull the orange ribbon from the number pad casing.
      • Set the number pad case to the side once it is detached from the ribbon.
      Ask FixBot
    3. LG CF360 Front Speaker Replacement: step 12, image 1 of 1
      Buy
      • Remove the two red sticker screw coverings at the top corners with tweezers.
      Ask FixBot
    4. LG CF360 Front Speaker Replacement: step 13, image 1 of 1
      • Unscrew the four Phillips #000 (3mm) screws at the corners of the phone.
      Ask FixBot
    5. LG CF360 Front Speaker Replacement: step 14, image 1 of 2 LG CF360 Front Speaker Replacement: step 14, image 2 of 2
      • Pry the red sliding backing from the front cover by inserting the plastic opening tool in between the two sections and going around the entire phone.
      • Set the red sliding backing and front cover to the side.
      Ask FixBot
    1. LG CF360 Front Speaker Replacement, Front Speaker: step 15, image 1 of 1
      • Be very careful to not damage the keypad board when using the plastic opening tool.
      • Gently pry the LCD ribbon from the left side of the front cover using the plastic opening tool.
      • One LCD ribbon is still connected to the keyboard, so do not attempt to remove it from the front cover.
      Ask FixBot
    2. LG CF360 Front Speaker Replacement: step 16, image 1 of 2 LG CF360 Front Speaker Replacement: step 16, image 2 of 2
      • Use the plastic opening tool to partially lift up the keyboard from the front of the phone.
      • Slowly rotate the keyboard clockwise while pulling it to the right to disconnect the second LCD ribbon from the keyboard.
      • Remove the keyboard from the phone and set aside.
      Ask FixBot
    3. LG CF360 Front Speaker Replacement: step 17, image 1 of 1
      • Do not attempt to completely remove the speaker from the phone at this point - it is still connected to the LCD screen.
      • Use the plastic opening tool to pry the front speaker from the phone.
      Ask FixBot
    4. LG CF360 Front Speaker Replacement: step 18, image 1 of 2 LG CF360 Front Speaker Replacement: step 18, image 2 of 2
      • Use a soldering iron to desolder the lead junctions. If you have never used a soldering iron or you need a refresher, check out iFixit's soldering guide.
      • Separate the speaker from the LCD screen.
      Ask FixBot
2 other people completed this guide.
Annie White
265 Reputation
2 Guides authored
Cal Poly, Team 4-27, Amido Fall 2013 Member of Cal Poly, Team 4-27, Amido Fall 2013
CPSU-AMIDO-F13S4G27
4 Members
96 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 31
Past 30 Days: 97
All Time: 855
