LG BP220 Motherboard Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
2
Past 7 Days:
22
Past 30 Days:
113
All Time:
5,545
Comments: 1
1 guide comment.
Go to guide comments
Completed: 6
6 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 20 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide will show you how to open up your Blu-ray player and remove the motherboard in order to replace various components of it or the whole unit.
Tools
    1. LG BP220 Motherboard Replacement, Motherboard: step 1, image 1 of 2 LG BP220 Motherboard Replacement, Motherboard: step 1, image 2 of 2
      • Ensure the device is unplugged to prevent shocks.
      • Remove the three black 3/16” Phillips #2 screws from the backside of the player.
      • With the backside (audio/video jacks) facing you, lift the part of the cover closer to you and pull until it is off.
      Ask FixBot
    2. LG BP220 Motherboard Replacement: step 2, image 1 of 3 LG BP220 Motherboard Replacement: step 2, image 2 of 3 LG BP220 Motherboard Replacement: step 2, image 3 of 3
      • Unhinge the tabs that attach the front panel to the unit:
      • Two tabs on the disc drive
      • Two tabs on the left and right side of the player
      • Be careful when handling these tabs. They are very fragile and can be easily broken.
      • Three tabs on the underside of the player
      • Pull panel away from case.
      • If the panel does not come off right away, be sure to check if tabs have inadvertently switched back to their locked position.
      Ask FixBot
    3. LG BP220 Motherboard Replacement: step 3, image 1 of 1
      • Using your fingers, pull the three tape-like cables to disconnect the disc drive from the green motherboard.
      Ask FixBot
    4. LG BP220 Motherboard Replacement: step 4, image 1 of 2 LG BP220 Motherboard Replacement: step 4, image 2 of 2
      • Remove the two black 3/16” Phillips #2 mounting screws from the left and right side of the disc drive.
      • With the front side facing you lift the front of disc drive, slide it toward you and pull out to remove.
      Ask FixBot
    5. LG BP220 Motherboard Replacement: step 5, image 1 of 3 LG BP220 Motherboard Replacement: step 5, image 2 of 3 LG BP220 Motherboard Replacement: step 5, image 3 of 3
      • Detach the power supply cord from the brown motherboard by pushing the locking clip on the connector, and pulling out.
      • The connector may be difficult to remove. Wiggling it while pulling out may help release it.
      • Remove the power cord from the panel by carefully sliding it upwards from its seating.
      Ask FixBot
    6. LG BP220 Motherboard Replacement: step 6, image 1 of 2 LG BP220 Motherboard Replacement: step 6, image 2 of 2
      • Remove the two black 3/16” Phillips #2 screws from the backside of the player.
      • One screw inbetween the audio/video jacks
      • One screw to the bottom right of the audio/video jacks
      • With the backside facing you, pull the bottom of the panel towards you and lift to remove it.
      Ask FixBot
    7. LG BP220 Motherboard Replacement: step 7, image 1 of 2 LG BP220 Motherboard Replacement: step 7, image 2 of 2
      • Handle the motherboards with care. They are fragile.
      • Beware of the capacitors as they may shock you when touched.
      • Remove the the two silver 3/16” Phillips #2 screws from the green motherboard.
      • Remove the one black 3/16” Phillips #2 screw from the brown motherboard
      • Use both hands to carefully lift the motherboard unit away from the player.
      Ask FixBot
6 other people completed this guide.
Bart Quicho
520 Reputation
3 Guides authored
UW Tacoma, Team 1-1, Rose Winter 2015 Member of UW Tacoma, Team 1-1, Rose Winter 2015
UWT-ROSE-W15S1G1
4 Members
36 Guides authored
1 Guide Comment
I need Ic htc lm37102 which is on this lg motherboard. How can i get that. I am not able to find
Email Id abhishek.mishra171983@gmail.com
Please let me know if you have this rgulator ic on my email id.
Thnx
Abhishek
Abhishek Mishra - Reply Share
Past 24 Hours: 2
Past 7 Days: 22
Past 30 Days: 113
All Time: 5,545
