LG Aristo MS210 Command Button Replacement
    1. LG Aristo MS210 Command Button Replacement, Battery: step 1, image 1 of 3 LG Aristo MS210 Command Button Replacement, Battery: step 1, image 2 of 3 LG Aristo MS210 Command Button Replacement, Battery: step 1, image 3 of 3
      • Insert the spudger into the notch on the bottom left side of the phone.
      • Apply light pressure to remove the back cover.
      Ask FixBot
    2. LG Aristo MS210 Command Button Replacement: step 2, image 1 of 2 LG Aristo MS210 Command Button Replacement: step 2, image 2 of 2
      • Insert the spudger into the notch located on the bottom middle of the battery.
      • Apply light pressure to remove the battery.
      Ask FixBot
    1. LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 1 of 3 LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 2 of 3 LG Aristo MS210 Command Button Replacement, Command Button: step 3, image 3 of 3
      • Use the PH000 bit unscrew the ten 3.4mm screws as highlighted.
      • Use the spudger to remove the inner shell.
      • Flip the inner shell over to expose the clips holding the command button.
      Ask FixBot
    2. LG Aristo MS210 Command Button Replacement: step 4, image 1 of 3 LG Aristo MS210 Command Button Replacement: step 4, image 2 of 3 LG Aristo MS210 Command Button Replacement: step 4, image 3 of 3
      • Use the spudger disconnect the three clips holding in the command button as highlighted.
      • Remove the command button.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 85
All Time: 654
