This translation was generated by a machine and has not been reviewed by a person yet. Speak this language? Review it.
LG Air Conditioner Deflector/Flap Motor Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
8
Past 7 Days:
56
Past 30 Days:
218
All Time:
2,260
Comments: 7
7 comments on steps.
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 hour
Difficulty: Difficult
    1. LG Air Conditioner Deflector/Flap Motor Replacement, Deflector/Flap Motor: step 1, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Deflector/Flap Motor: step 1, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Deflector/Flap Motor: step 1, image 3 of 3
      • Replacing the air deflector/flap motor for air outlet flow orientation in an LG Air Conditioner.
      • To get to the point you see in photo 3, the previous step is to disassemble the casing. This is indicated in Guide 1: Casing Disassembly.
      • Guide 2: Problem Diagnosis
      • In Photo 3, we see the motor on the right side of the unit.
      Ask FixBot
    2. LG Air Conditioner Deflector/Flap Motor Replacement, Inspection of the purchased spare part.: step 2, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Inspection of the purchased spare part.: step 2, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Inspection of the purchased spare part.: step 2, image 3 of 3
      • View of the original motor and the replacement motor (purchased on Aliexpress). The replacement has a shorter cable and a different connector, so you'll need to reuse a piece of cable and the connector from the faulty motor.
      • Photo 3: We see that the new motor's cable does not reach the PCB.
      Ask FixBot
    3. LG Air Conditioner Deflector/Flap Motor Replacement: step 3, image 1 of 2 LG Air Conditioner Deflector/Flap Motor Replacement: step 3, image 2 of 2
      • ATTENTION: WE WILL WORK SAFELY, WITH THE EQUIPMENT TURNED OFF AT THE ELECTRICAL PANEL.
      • Using a medium-sized Philips (+) screwdriver, loosen the two screws holding the motor and its connector to the PCB.
      Ask FixBot
    4. LG Air Conditioner Deflector/Flap Motor Replacement: step 4, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 4, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 4, image 3 of 3
      • Comparison: Faulty vs. Replacement Motor Here's a comparison between the faulty motor and the replacement motor. The latter has a different connector and a shorter cable. This means the purchased motor isn't a direct fit and needs to be adapted. This is likely due to the equipment's age, making it difficult to find an exact replacement part.
      Ask FixBot
    5. LG Air Conditioner Deflector/Flap Motor Replacement, Adapting the replacement motor's cable + connector to our motor.: step 5, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Adapting the replacement motor's cable + connector to our motor.: step 5, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Adapting the replacement motor's cable + connector to our motor.: step 5, image 3 of 3
      • You'll need to grab your soldering iron, solder, wire cutters (or scissors), and either heat-shrink tubing or electrical tape.
      • We'll reuse about 10 cm of cable plus the connector from the faulty motor. Cut the cable with the connector from the faulty motor, then cut the connector off the replacement motor. Finally, splice the cable from the faulty motor to the cable of the replacement motor.
      Ask FixBot
    6. LG Air Conditioner Deflector/Flap Motor Replacement: step 6, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 6, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 6, image 3 of 3
      • Views of the cable joining process.
      • ATTENTION: The order of the wires, starting with the yellow wire on the connector, matches the order of the flat cable's wires, starting with the white wire. YELLOW = WHITE, etc.
      Ask FixBot
    7. LG Air Conditioner Deflector/Flap Motor Replacement: step 7, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 7, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 7, image 3 of 3
      • First, cut the connector off the replacement motor, leaving a small piece of cable so you can see the color order.
      • Second, cut the cable from the faulty motor, leaving about 10 cm of cable plus the connector.
      • VERY IMPORTANT NOTE: The order of the motor's wires, starting with the yellow wire, is the one you must follow when splicing one cable to the other. YELLOW - WHITE
      Ask FixBot
    8. LG Air Conditioner Deflector/Flap Motor Replacement: step 8, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 8, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 8, image 3 of 3
      • We'll strip about 0.5 to 1 cm from the ends of the wires, insert the heat-shrink tubing, solder the two wires together, slide the tubing over the solder joint, and then heat the heat-shrink tubing. We'll repeat this cable by cable.
      Ask FixBot
    9. LG Air Conditioner Deflector/Flap Motor Replacement: step 9, image 1 of 2 LG Air Conditioner Deflector/Flap Motor Replacement: step 9, image 2 of 2
      • This time, since I don't have a heat gun handy, I'm using a lighter to heat and shrink the heat-shrink tubing.
      Ask FixBot
    10. LG Air Conditioner Deflector/Flap Motor Replacement: step 10, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 10, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 10, image 3 of 3
      • We'll reinstall the motor in the unit. Replace the two mounting screws and insert the connector into the PCB.
      Ask FixBot
    11. LG Air Conditioner Deflector/Flap Motor Replacement: step 11, image 1 of 1
      • View of the connector inserted.
      Ask FixBot
    12. LG Air Conditioner Deflector/Flap Motor Replacement: step 12, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 12, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 12, image 3 of 3
      • Now it's time to check if the motor is working correctly.
      • We'll place the deflector or FLAP. It won't engage with the motor normally, so we'll just "present it without inserting it in front of the motor's shaft." As soon as we power up the unit from the electrical panel, the motor will activate and search for its REST - CLOSED position, causing it to insert itself into the FLAP.
      Ask FixBot
    13. LG Air Conditioner Deflector/Flap Motor Replacement: step 13, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 13, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 13, image 3 of 3
      • At the other end of the house, after resetting the circuit breaker in the electrical panel, when I returned to the room where the unit is installed, the Flap had already closed and positioned itself, as we can see. It was in the CLOSED position.
      • Once the motor has been replaced, we'll test it to ensure it functions correctly: Video.
      Ask FixBot
    14. LG Air Conditioner Deflector/Flap Motor Replacement: step 14, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 14, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 14, image 3 of 3
      • Once you've confirmed it's working, you can try to reattach the cover without disassembling the Flap, but it's a bit complicated. It's more worthwhile to remove the Flap again and then reattach the cover without it.
      Ask FixBot
    15. LG Air Conditioner Deflector/Flap Motor Replacement: step 15, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 15, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 15, image 3 of 3
      • To insert the cover, it's easier to disassemble the FLAP again.
      Ask FixBot
    16. LG Air Conditioner Deflector/Flap Motor Replacement: step 16, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 16, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement: step 16, image 3 of 3
      • Once the casing is in place, reinstall its two screws and then reattach the flap.
      Ask FixBot
    17. LG Air Conditioner Deflector/Flap Motor Replacement, Flap Installation: step 17, image 1 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Flap Installation: step 17, image 2 of 3 LG Air Conditioner Deflector/Flap Motor Replacement, Flap Installation: step 17, image 3 of 3
      • To insert the flap, you'll need to bend it slightly on the motor side.
      Ask FixBot
    18. LG Air Conditioner Deflector/Flap Motor Replacement: step 18, image 1 of 2 LG Air Conditioner Deflector/Flap Motor Replacement: step 18, image 2 of 2
      • View of the FLAP inserted. We'll re-check its operation: turn the unit on with the remote, and the flap will open. If you press off, it'll return to the closed position.
      • End of Guide.
      Ask FixBot
To reassemble the device, follow the instructions in reverse order.
2 other people completed this guide.
Special thanks to these translators:
es en
100%
These translators are helping us fix the world! Want to contribute?
Start translating ›
Carlos López (España - Spain)
107,312 Reputation
397 Guides authored
0 Guide Comments
Past 24 Hours: 8
Past 7 Days: 56
Past 30 Days: 218
All Time: 2,260
