LG A275 Vibrator Replacement
    1. LG A275 Vibrator Replacement, Battery: step 1, image 1 of 2 LG A275 Vibrator Replacement, Battery: step 1, image 2 of 2
      • Turn the phone upside down so that the bottom of the back is facing you.
      Ask FixBot
    2. LG A275 Vibrator Replacement, Remove cover: step 2, image 1 of 2 LG A275 Vibrator Replacement, Remove cover: step 2, image 2 of 2
      • Slide the back down towards you and remove the back cover. You should hear a slight click as the cover comes off.
      Ask FixBot
    3. LG A275 Vibrator Replacement: step 3, image 1 of 1
      • Gently remove the battery from the device.
      Ask FixBot
    1. LG A275 Vibrator Replacement, Vibrator: step 4, image 1 of 3 LG A275 Vibrator Replacement, Vibrator: step 4, image 2 of 3 LG A275 Vibrator Replacement, Vibrator: step 4, image 3 of 3
      • Using the plastic opening tool, wedge it around the edge of the phone to release the front plastic piece from the phone.
      • Be careful when using the plastic opening tool not to brute force the phone open, the plastics are fragile.
      Ask FixBot
    2. LG A275 Vibrator Replacement: step 5, image 1 of 2 LG A275 Vibrator Replacement: step 5, image 2 of 2
      • After separating the two plastic halves of the phone, take the plastic that does not have the motherboard attached to it. The plastic has a small yellow component with a lob-sided magnet within it. This is the vibrator of the phone, pull this piece out with your hand. This piece is free floating and will simply drop out.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order after placing in the new vibrator.
Nathanael Knight
181 Reputation
2 Guides authored
IUPUI, Team S3-G1, Harley Spring 2018 Member of IUPUI, Team S3-G1, Harley Spring 2018
IUPUI-HARLEY-S18S3G1
3 Members
23 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 32
All Time: 412
