LG 440G Logic Board Replacement
    1. LG 440G Logic Board Replacement, Turn off phone.: step 1, image 1 of 1
      • Turn the device off.
      • To do so, press and hold the red button.
      Ask FixBot
    2. LG 440G Logic Board Replacement, Flip phone.: step 2, image 1 of 1
      • Flip the phone over.
      Ask FixBot
    3. LG 440G Logic Board Replacement, Rear cover removal.: step 3, image 1 of 1
      • Slide the rear cover downward
      • Lift it off to access the battery
      Ask FixBot
    4. LG 440G Logic Board Replacement, Removal of battery.: step 4, image 1 of 1
      • Locate the small rounded recess to get access to the battery
      • Gently, lift the battery
      Ask FixBot
    1. LG 440G Logic Board Replacement, Unscrew six screws along edges of casing: step 5, image 1 of 1
      • Use a Phillips #00 screw driver to remove six screws.
      • Save screws for reassembly.
      Ask FixBot
    2. LG 440G Logic Board Replacement, Lift casing cover: step 6, image 1 of 2 LG 440G Logic Board Replacement, Lift casing cover: step 6, image 2 of 2
      • Run the plastic opening tool along the edge of the phone to release the casing cover.
      • Lift the casing cover.
      Ask FixBot
    1. LG 440G Logic Board Replacement, Remove rectangular piece (with orange tape attached): step 7, image 1 of 2 LG 440G Logic Board Replacement, Remove rectangular piece (with orange tape attached): step 7, image 2 of 2
      • Use the plastic opening tool or fingernail to lift the rectangular piece up. The piece can be identified by the orange tape attached to it.
      Ask FixBot
    2. LG 440G Logic Board Replacement, Dislodge logic board: step 8, image 1 of 1
      • Dislodge the logic board using a plastic opening tool.
      Ask FixBot
    3. LG 440G Logic Board Replacement, Lift logic board out: step 9, image 1 of 1
      • Remove the logic board by lifting up.
      Ask FixBot
2 other people completed this guide.
JP Belanger
225 Reputation
2 Guides authored
Ohio State, Team 1-1, Buehl Winter 2015 Member of Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Members
48 Guides authored
1 Guide Comment
Hi, do you know how to take the microphone out without damaging the functionality of the phone? It’s attached to a ribbon that is soldered on. Thanks!
Kobalt000 - Reply Share
Past 24 Hours: 1
Past 7 Days: 1
Past 30 Days: 19
All Time: 1,334
