Up to 20% off select tools
LG 440G Bottom Casing Replacement
Views: 2.3K
View statistics:
Past 24 Hours:
5
Past 7 Days:
21
Past 30 Days:
108
All Time:
2,338
Comments: 1
1 guide comment.
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 10 - 15 minutes
Difficulty: Moderate
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Tools
Introduction
Go to step 1 ↓
This guide helps you to replace the rear casing of a LG 440G Phone.
The rear casing of your phone plays a crucial role in protecting its internal components from damage and wear. Over time, it can become cracked, scratched, or loose, compromising the phone's durability and appearance. Replacing the rear casing can restore your phone’s structural integrity and give it a refreshed look.
Before you begin, make sure that your phone is powered off and it is unplugged from the charger.
    1. LG 440G Bottom Casing Replacement, Turn off phone.: step 1, image 1 of 1
      • Turn the device off.
      • To do so, press and hold the red button.
      Ask FixBot
    2. LG 440G Bottom Casing Replacement, Flip phone.: step 2, image 1 of 1
      • Flip the phone over.
      Ask FixBot
    3. LG 440G Bottom Casing Replacement, Rear cover removal.: step 3, image 1 of 1
      • Slide the rear cover downward
      • Lift it off to access the battery
      Ask FixBot
    4. LG 440G Bottom Casing Replacement, Removal of battery.: step 4, image 1 of 1
      • Locate the small rounded recess to get access to the battery
      • Gently, lift the battery
      Ask FixBot
    1. LG 440G Bottom Casing Replacement, Unscrew six screws along edges of casing: step 5, image 1 of 1
      • Use a Phillips #00 screw driver to remove six screws.
      • Save screws for reassembly.
      Ask FixBot
    2. LG 440G Bottom Casing Replacement, Lift casing cover: step 6, image 1 of 2 LG 440G Bottom Casing Replacement, Lift casing cover: step 6, image 2 of 2
      • Run the plastic opening tool along the edge of the phone to release the casing cover.
      • Lift the casing cover.
      Ask FixBot
Author
with
Emily Class
107 Reputation
1 Guide authored
Ohio State, Team 1-1, Buehl Winter 2015 Member of Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Members
48 Guides authored
1 Guide Comment
this would be most probably, the same guide to tear down the LG B470
douglas flores - Reply Share
Past 24 Hours: 5
Past 7 Days: 21
Past 30 Days: 108
All Time: 2,338
