Up to 20% off select tools
LG 440G Battery Replacement
Views: 8.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
18
Past 30 Days:
95
All Time:
8,704
Comments: 5
5 guide comments.
Go to guide comments
Completed: 4
4 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Easy
Step Trimmer
This guide has unnecessary steps. Trim them to be more concise!
Introduction
Go to step 1 ↓
This guide shows how to change the battery in a LG 440G flip phone.
The user may need to change the battery if the flip phone is running slow, not turning on, or has lost capability or ability to hold charge. No special skills or tools are required, although you will need to purchase the new battery from LG.
Before beginning to replace the battery, make sure to turn your device off. The guide will help you with this.
    1. LG 440G Battery Replacement, Turn off phone.: step 1, image 1 of 1
      • Turn the device off.
      • To do so, press and hold the red button.
      Ask FixBot
    2. LG 440G Battery Replacement, Flip phone.: step 2, image 1 of 1
      • Flip the phone over.
      Ask FixBot
    3. LG 440G Battery Replacement, Rear cover removal.: step 3, image 1 of 1
      • Slide the rear cover downward
      • Lift it off to access the battery
      Ask FixBot
    4. LG 440G Battery Replacement, Removal of battery.: step 4, image 1 of 1
      • Locate the small rounded recess to get access to the battery
      • Gently, lift the battery
      Ask FixBot
4 other people completed this guide.
Author
with
Chris
200 Reputation
1 Guide authored
Ohio State, Team 1-1, Buehl Winter 2015 Member of Ohio State, Team 1-1, Buehl Winter 2015
OSU-BUEHL-W15S1G1
4 Members
48 Guides authored
5 Guide Comments
The back cover does not move at all.  I even tried to insert the tip of a steak knife on the top, but nothing.  It will not budge.  I have an LG 440G Tracfone.  Since I was not able to check the battery due to not getting the back off, I bought another one.  I just decided to retry but nothing.
carolaerhardt - Reply Share
Cannot open back of Tracfone 440G to check battery….it does not budge.
Need to replace battery in LG fliphone. Back cover will not slide down Why ? When one cannot open back cover to replace battery it makes the LG flip phone junk.. or as they say in England rubbish.
Hex Ram - Reply Share
Unfortunately, LG does not appear to sell batteries anymore, so if your phone needs a new one you're screwed.
John Dont - Reply Share
Past 24 Hours: 4
Past 7 Days: 18
Past 30 Days: 95
All Time: 8,704
