LG 305C Speaker Replacement
View statistics:
Past 24 Hours:
5
Past 7 Days:
14
Past 30 Days:
49
All Time:
501
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 minutes
Difficulty: Moderate
Introduction
Go to step 1 ↓
Before completing this replacement guide, it is important to unplug the device. This replacement guide will show how to replace the speaker in the device.
Tools
    1. LG 305C Speaker Replacement, Battery: step 1, image 1 of 1
      • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
      Ask FixBot
    2. LG 305C Speaker Replacement: step 2, image 1 of 1
      • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
      Ask FixBot
    1. LG 305C Speaker Replacement, Internal Casing: step 3, image 1 of 1
      • Remove the three 4 mm screws using a JIS screwdriver with a J000 head from the bottom part of the internal casing.
      Ask FixBot
    2. LG 305C Speaker Replacement: step 4, image 1 of 1
      • Pry open the bottom part of the internal casing with the plastic opening tool and remove it.
      Ask FixBot
    3. LG 305C Speaker Replacement: step 5, image 1 of 1
      • Remove the four 4 mm screws using a JIS screwdriver with a J000 head from the top part of the internal casing.
      Ask FixBot
    4. LG 305C Speaker Replacement: step 6, image 1 of 1
      • Pry open the top part of the internal casing with the plastic opening tool and remove it.
      Ask FixBot
    1. LG 305C Speaker Replacement, Speaker: step 7, image 1 of 1
      • Insert plastic opening tool under the plastic flap and lift the speaker out.
      Ask FixBot
Joaquin Garcia
73 Reputation
1 Guide authored
IUPUI, Team S6-G1, Baechle Spring 2018 Member of IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 14
Past 30 Days: 49
All Time: 501
