Up to 20% off select tools
LG 305C Battery Replacement
View statistics:
Past 24 Hours:
Past 7 Days:
3
Past 30 Days:
49
All Time:
672
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 2 - 5 minutes
Difficulty: Very easy
Better Introduction
Improve this guide by completing or revising its introduction.
Student In Progress
This guide is being worked on by hardworking students.
Tools
Introduction
Go to step 1 ↓
This guide explains how to remove the battery from the LG 305 TracFone touchscreen phone, also known as the LG 305C TracFone. The battery is a rechargeable part that supplies power to the phone when it is not connected to a charger. If your phone drains its battery quickly, will only turn on while connected to a charger, or will not turn on because the battery has no charge, you may need to check the battery.
Before replacing it, review the LG 305C Troubleshooting Guide, especially the sections on Battery Is Not Charging and Screen Is Black, since charging problems can also be caused by a faulty charger or charging cable.
Safety: Before beginning, turn off the phone and disconnect it from its charger. Use a plastic opening tool to help remove the back cover and battery. Avoid bending, puncturing, or damaging the battery. If the battery appears swollen or damaged, stop the repair and follow iFixit's swollen battery safety recommendations.
After removing an old battery, dispose of it properly through an appropriate electronics or battery recycling program. R2 or e-Stewards certified recycler.
    1. LG 305C Battery Replacement, Battery: step 1, image 1 of 1
      • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
      Ask FixBot
    2. LG 305C Battery Replacement: step 2, image 1 of 1
      • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
      Ask FixBot
To reassemble your device, follow these instructions in reverse order. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
Ashley Kidwell
454 Reputation
5 Guides authored
IUPUI, Team S6-G1, Baechle Spring 2018 Member of IUPUI, Team S6-G1, Baechle Spring 2018
IUPUI-BAECHLE-S18S6G1
3 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 49
All Time: 672
