Up to 20% off select tools
LG 305C Touch Screen Assembly Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
16
Past 30 Days:
97
All Time:
950
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 25 - 40 minutes
Difficulty: Moderate
Student In Progress
This guide is being worked on by hardworking students.
Slice and Dice
The steps in this guide should be split up and made into a series of prerequisite guides.
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
Introduction
Go to step 1 ↓
Please follow our first few steps to identify your device and ensure that it is applicable to this guide. Once this is completed you may begin the process of replacing your screen.
    1. LG 305C  Touch Screen Assembly Replacement, Battery: step 1, image 1 of 1
      • Pry open the back case on the device with a plastic opening tool going around the edges of the device to ensure it is taken off with no damage then finally remove it and place it on the side.
      Ask FixBot
    2. LG 305C  Touch Screen Assembly Replacement: step 2, image 1 of 1
      • Pry the battery out of the device with a plastic opening tool opposite from the plastic pieces keeping it in place and remove it gently in order to ensure that you don’t damage it.
      Ask FixBot
    1. LG 305C  Touch Screen Assembly Replacement, Touch Screen: step 3, image 1 of 2 LG 305C  Touch Screen Assembly Replacement, Touch Screen: step 3, image 2 of 2
      • Unscrew the back of your device and on the white strip underneath, it should read LG 305C.
      • Note: If it does not read LG305C as the model number, please refer to another guide in order to replace your screen.
      Ask FixBot
    2. LG 305C  Touch Screen Assembly Replacement, SD Card Removal: step 4, image 1 of 1
      Ask FixBot
    3. LG 305C  Touch Screen Assembly Replacement: step 5, image 1 of 3 LG 305C  Touch Screen Assembly Replacement: step 5, image 2 of 3 LG 305C  Touch Screen Assembly Replacement: step 5, image 3 of 3
      • Use a Phillips #00 screwdriver to remove the seven screws that are located along the edges of the device.
      Ask FixBot
    4. LG 305C  Touch Screen Assembly Replacement: step 6, image 1 of 2 LG 305C  Touch Screen Assembly Replacement: step 6, image 2 of 2
      • Using your plastic pry tool, pry along the edges of plastic side of the screen to loosen and separate the first screen layer.
      • As shown in Picture 2, push in the notch along the edge of the charging port.
      Ask FixBot
    5. LG 305C  Touch Screen Assembly Replacement: step 7, image 1 of 3 LG 305C  Touch Screen Assembly Replacement: step 7, image 2 of 3 LG 305C  Touch Screen Assembly Replacement: step 7, image 3 of 3
      • Remove the front end of the screen by gently swinging it out from its notched in position as shown.
      Ask FixBot
    6. LG 305C  Touch Screen Assembly Replacement: step 8, image 1 of 2 LG 305C  Touch Screen Assembly Replacement: step 8, image 2 of 2
      • Gently pry off the touch screen connection attached to the motherboard with your finger.
      • Once detached, gently separate the motherboard and plastic screen mold. It should look the same as Picture 2
      Ask FixBot
To reassemble your device, follow the steps in reverse. Take your e-waste to an R2 or e-Stewards certified recycler.
Author
with
alex Benitez
124 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 16
Past 30 Days: 97
All Time: 950
