LG 29WK600 Control Board Replacement
View statistics:
Past 24 Hours:
3
Past 7 Days:
32
Past 30 Days:
134
All Time:
476
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 1 hour
Difficulty: Moderate
Community-Contributed Guide
Introduction
Go to step 1 ↓
This guide will demonstrate how to replace the control panel of the LG 29WK600 monitor. It will take approximately 1 to 1.5 hours.
Tools
    1. LG 29WK600 Control Board Replacement, Control Board: step 1, image 1 of 1
      • Remove the stand of the monitor and place it on a soft surface (such as a cushion)
      Ask FixBot
    2. LG 29WK600 Control Board Replacement: step 2, image 1 of 1
      • Remove the screws located near the display interface
      Ask FixBot
    3. LG 29WK600 Control Board Replacement: step 3, image 1 of 2 LG 29WK600 Control Board Replacement: step 3, image 2 of 2
      • This is the most challenging part. Starting from the side of the monitor, insert a pry bar into the junction between the black plastic and the white plastic, and then pry open the clips inside the monitor.
      • You can pry open the back panel of the monitor in the way shown in the second picture.
      Ask FixBot
    4. LG 29WK600 Control Board Replacement: step 4, image 1 of 1
      • This is the interior of the monitor after the back panel has been removed.
      Ask FixBot
    5. LG 29WK600 Control Board Replacement: step 5, image 1 of 2 LG 29WK600 Control Board Replacement: step 5, image 2 of 2
      • First, disconnect the five cables connecting the control board. Lift the black plastic flap on the flat ribbon cable connector before removing it (the second picture).
      • Then, remove the four screws from the corners.
      Ask FixBot
      • Replace the new control panel and then, following the reverse process of the previous steps, reassemble it.
      Ask FixBot
Lawrence H
133 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 32
Past 30 Days: 134
All Time: 476
