Up to 20% off select tools
LG 1010 LCD Screen Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
87
All Time:
1,687
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 30 minutes
Difficulty: Difficult
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
    1. LG 1010 LCD Screen Replacement, Battery: step 1, image 1 of 1
      • Turn off the cell phone and place face down on a flat surface.
      Ask FixBot
    2. LG 1010 LCD Screen Replacement: step 2, image 1 of 2 LG 1010 LCD Screen Replacement: step 2, image 2 of 2
      • While sliding the gray tab up, lift battery up and away from the cell phone.
      Ask FixBot
    3. LG 1010 LCD Screen Replacement: step 3, image 1 of 3 LG 1010 LCD Screen Replacement: step 3, image 2 of 3 LG 1010 LCD Screen Replacement: step 3, image 3 of 3
      • Remove battery and set aside.
      Ask FixBot
    1. LG 1010 LCD Screen Replacement, Front  Cover: step 4, image 1 of 2 LG 1010 LCD Screen Replacement, Front  Cover: step 4, image 2 of 2
      • Use a Spudger to remove the two front plastic covers to reveal screws.
      Ask FixBot
    2. LG 1010 LCD Screen Replacement: step 5, image 1 of 1
      • Remove two screws using a Torx T6 screwdriver.
      Ask FixBot
    3. LG 1010 LCD Screen Replacement: step 6, image 1 of 2 LG 1010 LCD Screen Replacement: step 6, image 2 of 2
      • Pry off the screen front cover with a small flathead screwdriver.
      Ask FixBot
    4. LG 1010 LCD Screen Replacement: step 7, image 1 of 1
      • Insert a small flathead screwdriver into the hinge and separate hinge connection.
      Ask FixBot
    5. LG 1010 LCD Screen Replacement: step 8, image 1 of 1
      • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
      Ask FixBot
    6. LG 1010 LCD Screen Replacement: step 9, image 1 of 1
      • Remove remaining portion of the front case from the flexible circuit board.
      • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
      Ask FixBot
    1. LG 1010 LCD Screen Replacement, Back Cover: step 10, image 1 of 2 LG 1010 LCD Screen Replacement, Back Cover: step 10, image 2 of 2
      • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
      Ask FixBot
    2. LG 1010 LCD Screen Replacement: step 11, image 1 of 2 LG 1010 LCD Screen Replacement: step 11, image 2 of 2
      • Pull the back cover straight off the phone using your thumb and forefinger.
      Ask FixBot
    1. LG 1010 LCD Screen Replacement, Keypad: step 12, image 1 of 1
      • Pry off circuit board with a flathead screwdriver.
      Ask FixBot
    2. LG 1010 LCD Screen Replacement: step 13, image 1 of 1
      • Pull out flexible keypad.
      Ask FixBot
    1. LG 1010 LCD Screen Replacement, LCD Screen: step 14, image 1 of 1
      • The phone should now look like the picture to the left.
      Ask FixBot
    2. LG 1010 LCD Screen Replacement: step 15, image 1 of 2 LG 1010 LCD Screen Replacement: step 15, image 2 of 2
      • Locate and detach the ribbon cable from circuit board.
      Ask FixBot
    3. LG 1010 LCD Screen Replacement: step 16, image 1 of 2 LG 1010 LCD Screen Replacement: step 16, image 2 of 2
      • Remove the LCD Screen from the phone case and replace with a new LCD screen.
      Ask FixBot
2 other people completed this guide.
Author
with
Nicholas Schmidt
97 Reputation
7 Guides authored
Cal Poly, Team 3-25, Regan Fall 2010 Member of Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 87
All Time: 1,687
