Up to 20% off select tools
LG 1010 Keypad Replacement
Views: 1.6K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
86
All Time:
1,606
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Tools
Introduction
Go to step 1 ↓
This repair guide will instruct the user on the proper technique for removing and replacing a broken keypad for a LG 1010 Cell Phone.
    1. LG 1010 Keypad Replacement, Battery: step 1, image 1 of 1
      • Turn off the cell phone and place face down on a flat surface.
      Ask FixBot
    2. LG 1010 Keypad Replacement: step 2, image 1 of 2 LG 1010 Keypad Replacement: step 2, image 2 of 2
      • While sliding the gray tab up, lift battery up and away from the cell phone.
      Ask FixBot
    3. LG 1010 Keypad Replacement: step 3, image 1 of 3 LG 1010 Keypad Replacement: step 3, image 2 of 3 LG 1010 Keypad Replacement: step 3, image 3 of 3
      • Remove battery and set aside.
      Ask FixBot
    1. LG 1010 Keypad Replacement, Antenna: step 4, image 1 of 1
      • While holding cell phone firmly in one hand, unscrew and remove the antenna with the other hand.
      Ask FixBot
    2. LG 1010 Keypad Replacement: step 5, image 1 of 2 LG 1010 Keypad Replacement: step 5, image 2 of 2
      • Pull the antenna housing (black tube) towards bottom of phone and remove.
      Ask FixBot
    1. LG 1010 Keypad Replacement, Back Cover: step 6, image 1 of 2 LG 1010 Keypad Replacement, Back Cover: step 6, image 2 of 2
      • Unscrew the four screws on the back case using a T6 Torx Screwdriver.
      Ask FixBot
    2. LG 1010 Keypad Replacement: step 7, image 1 of 2 LG 1010 Keypad Replacement: step 7, image 2 of 2
      • Pull the back cover straight off the phone using your thumb and forefinger.
      Ask FixBot
    1. LG 1010 Keypad Replacement, Keypad: step 8, image 1 of 1
      • Pry off circuit board with a flathead screwdriver.
      Ask FixBot
    2. LG 1010 Keypad Replacement: step 9, image 1 of 1
      • Pull out flexible keypad.
      Ask FixBot
Install new keypad and reassemble following these instructions in reverse order.
2 other people completed this guide.
Author
with
Nicholas Schmidt
97 Reputation
7 Guides authored
Cal Poly, Team 3-25, Regan Fall 2010 Member of Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 86
All Time: 1,606
