Up to 20% off select tools
LG 1010 Front Cover Replacement
Views: 1.7K
View statistics:
Past 24 Hours:
5
Past 7 Days:
18
Past 30 Days:
88
All Time:
1,660
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Incorrect Tools
Help make this guide better by using the correct tools in images and/or text.
Missing Prerequisites
This guide is missing information on how to start the process. Make a prerequisite guide!
Tools
    1. LG 1010 Front Cover Replacement, Front  Cover: step 1, image 1 of 2 LG 1010 Front Cover Replacement, Front  Cover: step 1, image 2 of 2
      • Use a Spudger to remove the two front plastic covers to reveal screws.
      Ask FixBot
    2. LG 1010 Front Cover Replacement: step 2, image 1 of 1
      • Remove two screws using a Torx T6 screwdriver.
      Ask FixBot
    3. LG 1010 Front Cover Replacement: step 3, image 1 of 2 LG 1010 Front Cover Replacement: step 3, image 2 of 2
      • Pry off the screen front cover with a small flathead screwdriver.
      Ask FixBot
    4. LG 1010 Front Cover Replacement: step 4, image 1 of 1
      • Insert a small flathead screwdriver into the hinge and separate hinge connection.
      Ask FixBot
    5. LG 1010 Front Cover Replacement: step 5, image 1 of 1
      • Pry off the speaker which is glued on to the front cover using a small flathead screwdriver.
      Ask FixBot
    6. LG 1010 Front Cover Replacement: step 6, image 1 of 1
      • Remove remaining portion of the front case from the flexible circuit board.
      • Do not attempt to remove the LCD board at this time, as it is attached to the rear panel assembly.
      Ask FixBot
Author
with
Nicholas Schmidt
97 Reputation
7 Guides authored
Cal Poly, Team 3-25, Regan Fall 2010 Member of Cal Poly, Team 3-25, Regan Fall 2010
CPSU-REGAN-F10S3G25
4 Members
84 Guides authored
0 Guide Comments
Past 24 Hours: 5
Past 7 Days: 18
Past 30 Days: 88
All Time: 1,660
