LERSTA Floor Lamp Screw Terminal Replacement
    1. LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: step 1, image 1 of 2 LERSTA Floor Lamp Screw Terminal Replacement, Screw Terminal: step 1, image 2 of 2
      • Unplug the lamp.
      Ask FixBot
    2. LERSTA Floor Lamp Screw Terminal Replacement: step 2, image 1 of 1
      • Rotate the bulb counterclockwise to remove the light bulb.
      Ask FixBot
    3. LERSTA Floor Lamp Screw Terminal Replacement: step 3, image 1 of 1
      • Rotate the lamp shade counterclockwise.
      Ask FixBot
    4. LERSTA Floor Lamp Screw Terminal Replacement: step 4, image 1 of 1
      • Take the three parts aside after dismantling the lamp shade.
      Ask FixBot
    5. LERSTA Floor Lamp Screw Terminal Replacement: step 5, image 1 of 1
      • Dismantle the lamp shaft by rotating it counterclockwise.
      Ask FixBot
    6. LERSTA Floor Lamp Screw Terminal Replacement: step 6, image 1 of 1
      • Use a Phillips screwdriver to remove the two 3 mm screws from the silver cover.
      • Pull down both the silver cover and the black screw terminal.
      Ask FixBot
    7. LERSTA Floor Lamp Screw Terminal Replacement: step 7, image 1 of 1
      • Separate the light bulb socket from the silver cover by pulling the silver metal hasp in right-downward direction towards the lamp shaft.
      • Exert force on the both left and right hand sides of the hasp and then pull the hasp downward.
      Ask FixBot
    8. LERSTA Floor Lamp Screw Terminal Replacement: step 8, image 1 of 1
      • Replace the old bulb socket with a newly-purchased one.
      Ask FixBot
Replacing the screw terminal of the floor lamp is relatively easy, but be cautious to deal with the step of the substitution of the light socket.
[deleted]
157 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 13
Past 30 Days: 63
All Time: 1,857
