Up to 20% off select tools
LCD X2gen Display disassembly
Views: 3K
View statistics:
Past 24 Hours:
7
Past 7 Days:
37
Past 30 Days:
155
All Time:
3,010
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 5
5 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: No estimate
Difficulty: Moderate
Action Shots
Be an action hero! This guide needs images that better demonstrate how to perform specific actions.
Needs Better Images
Better photos will improve this guide. Help out by taking, editing, or uploading new ones!
Needs More Images
A few more images would make this guide's procedures crystal clear.
Community-Contributed Guide
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. LCD X2gen Display disassembly, Display: step 1, image 1 of 1
      • X2gen 22 lcd Screen repair guide
      Ask FixBot
    2. LCD X2gen Display disassembly: step 2, image 1 of 1
      • Power board displaying the capacitors to be replaced
      Ask FixBot
    3. LCD X2gen Display disassembly: step 3, image 1 of 1
      • Display viewed laying face down on the working table (my dining table)
      • Remove the 6 screws. 4 on the corners and 2 middle bottom.
      Ask FixBot
    4. LCD X2gen Display disassembly: step 4, image 1 of 1
      • Remove front bezel by lifting softly starting from the middle and moving out to the corners.
      Ask FixBot
    5. LCD X2gen Display disassembly: step 5, image 1 of 1
      • Top middle
      Ask FixBot
    6. LCD X2gen Display disassembly: step 6, image 1 of 1
      • Front bezel removed.
      • Observe: the control board, bottom right.
      • exposed screws on both sides (4 left, 4 right) holding the LCD to the back cover.
      Ask FixBot
    7. LCD X2gen Display disassembly: step 7, image 1 of 1
      • Prepare to remove the 4 screws on each side to lift the LCD. Do not try to remove it after unscrewing the 8 screws. There are cables connected on the back.
      • This pic shows the right side
      Ask FixBot
    8. LCD X2gen Display disassembly: step 8, image 1 of 1
      • This pic shows the left side
      Ask FixBot
    9. LCD X2gen Display disassembly: step 9, image 1 of 2 LCD X2gen Display disassembly: step 9, image 2 of 2
      • Lift carefully about 2 inch to expose the back light connections, 2 pink and 2 white.
      • Slide the monitor to the left about 3-4 inch. to have access to the connections.
      Ask FixBot
    10. LCD X2gen Display disassembly: step 10, image 1 of 1
      • Carefully, unplug both connectors
      Ask FixBot
    11. LCD X2gen Display disassembly: step 11, image 1 of 2 LCD X2gen Display disassembly: step 11, image 2 of 2
      • After removing the connectors, slide it about 3-5 inches to the right to have access to the data connector and ground
      Ask FixBot
    12. LCD X2gen Display disassembly: step 12, image 1 of 1
      • Remove the data connector and ground.
      Ask FixBot
      • Lift display. Is now completely free
      Ask FixBot
2 other people completed this guide.
Author
with
Aleks
201 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 7
Past 7 Days: 37
Past 30 Days: 155
All Time: 3,010
