Up to 20% off select tools
LCD Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
31
Past 30 Days:
116
All Time:
816
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 4 minutes
Difficulty: Moderate
Community-Contributed Guide
LCD Replacement
    1. LCD Replacement, Rear Cover: step 1, image 1 of 1
      • First ensure your laptop is turned off and check if you have the necessary tools
      Ask FixBot
    2. LCD Replacement: step 2, image 1 of 2 LCD Replacement: step 2, image 2 of 2
      • All screws are identified by circles. Pay special attention to the yellow circles, as the rubber feet hide screws.
      Ask FixBot
    3. LCD Replacement: step 3, image 1 of 3 LCD Replacement: step 3, image 2 of 3 LCD Replacement: step 3, image 3 of 3
      • With the opening tool, remove a rubber foot.
      • For this action you will have to exert some force, because the foot is glued with a resistant glue.
      Ask FixBot
    4. LCD Replacement: step 4, image 1 of 1
      • Remove all screws with a Philips screwdriver PH1
      • All screws are the same so don't worry about identifying them.
      Ask FixBot
    5. LCD Replacement: step 5, image 1 of 3 LCD Replacement: step 5, image 2 of 3 LCD Replacement: step 5, image 3 of 3
      • With the plastic tool, insert between the plastics and gently pry open.
      • With your fingers continue to force open the bottom cover on the side indicated in the figure.
      • You will feel and hear several clicks, perfectly normal, nothing is breaking. Remove the cover completely.
      Ask FixBot
    6. LCD Replacement: step 6, image 1 of 1
      • Finally, we have the laptop open and ready to replace most of its components. Look elsewhere on how to replace a component.
      • To close the laptop just follow this guide in reverse.
      Ask FixBot
      • Insert instructions here.
      Ask FixBot
To reassemble your device, follow the previous steps in inverse order.
Special thanks to these translators:
pt en
100%
David is helping us fix the world! Want to contribute?
Start translating ›
Author
with
Nelson Oliveira
756 Reputation
4 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 31
Past 30 Days: 116
All Time: 816
