Kyvol Cybovac L20 Sensor Replacement
    1. Kyvol Cybovac L20 Sensor Replacement, Battery: step 1, image 1 of 1
      • Begin with the device laying on a flat surface with the power button facing up.
      Ask FixBot
    2. Kyvol Cybovac L20 Sensor Replacement: step 2, image 1 of 2 Kyvol Cybovac L20 Sensor Replacement: step 2, image 2 of 2
      • Remove both of the side brushes.
      Ask FixBot
    3. Kyvol Cybovac L20 Sensor Replacement: step 3, image 1 of 1
      • Use a Phillips #1 screwdriver to remove two 1 mm screws that secure the panel.
      • Remove the battery panel.
      Ask FixBot
    4. Kyvol Cybovac L20 Sensor Replacement: step 4, image 1 of 2 Kyvol Cybovac L20 Sensor Replacement: step 4, image 2 of 2
      • Slightly lift the battery out of the compartment.
      • Disconnect the battery connector.
      • Completely remove the battery.
      Ask FixBot
    1. Kyvol Cybovac L20 Sensor Replacement, Sensor: step 5, image 1 of 1
      • Remove the eight 12.2 mm Phillips screws.
      Ask FixBot
    2. Kyvol Cybovac L20 Sensor Replacement: step 6, image 1 of 3 Kyvol Cybovac L20 Sensor Replacement: step 6, image 2 of 3 Kyvol Cybovac L20 Sensor Replacement: step 6, image 3 of 3
      • Lift the body away from the base and disconnect all connectors between the two halves.
      Ask FixBot
    3. Kyvol Cybovac L20 Sensor Replacement: step 7, image 1 of 1
      • Remove the two 8 mm Phillips screws that secure the sensor.
      Ask FixBot
    4. Kyvol Cybovac L20 Sensor Replacement: step 8, image 1 of 2 Kyvol Cybovac L20 Sensor Replacement: step 8, image 2 of 2
      • Use a spudger or your fingernails to gently walk the white connector directly out of its port.
      • Remove the sensor.
      Ask FixBot
Brad
397 Reputation
3 Guides authored
IUPUI, Team 1-1, Harley Spring 2024 Member of IUPUI, Team 1-1, Harley Spring 2024
IUPUI-HARLEY-S24S1G1
3 Members
36 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 3
Past 30 Days: 26
All Time: 411
