Kyocera Zio M6000 Motherboard Replacement
    1. Kyocera Zio M6000 Motherboard Replacement, Battery: step 1, image 1 of 2 Kyocera Zio M6000 Motherboard Replacement, Battery: step 1, image 2 of 2
      • Press down on the back of the phone, applying moderate pressure.
      • Slide the back casing down to separate it.
      Ask FixBot
    2. Kyocera Zio M6000 Motherboard Replacement: step 2, image 1 of 2 Kyocera Zio M6000 Motherboard Replacement: step 2, image 2 of 2
      • Remove the back casing to expose the battery.
      • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
      Ask FixBot
    1. Kyocera Zio M6000 Motherboard Replacement, Motherboard: step 3, image 1 of 2 Kyocera Zio M6000 Motherboard Replacement, Motherboard: step 3, image 2 of 2
      • Remove the six 3.18 mm screws using a Phillips 00 screwdriver.
      Ask FixBot
    2. Kyocera Zio M6000 Motherboard Replacement: step 4, image 1 of 2 Kyocera Zio M6000 Motherboard Replacement: step 4, image 2 of 2
      • Insert the flat end of the spudger between the front and back panels, and pry it apart by running the spudger along the side to further separate them.
      • Go all the way around, prying as you go, until the back casing completely separates from the rest of the phone.
      Ask FixBot
    3. Kyocera Zio M6000 Motherboard Replacement: step 5, image 1 of 3 Kyocera Zio M6000 Motherboard Replacement: step 5, image 2 of 3 Kyocera Zio M6000 Motherboard Replacement: step 5, image 3 of 3
      • Unclip the two flex cables -- a small one located on the left side on the lower half of the motherboard, and a longer one on the right side, higher up.
      Ask FixBot
    4. Kyocera Zio M6000 Motherboard Replacement: step 6, image 1 of 3 Kyocera Zio M6000 Motherboard Replacement: step 6, image 2 of 3 Kyocera Zio M6000 Motherboard Replacement: step 6, image 3 of 3
      • Pry out the earpiece speaker using the spudger.
      • Pry out the vibration motor using the spudger.
      Ask FixBot
    5. Kyocera Zio M6000 Motherboard Replacement: step 7, image 1 of 2 Kyocera Zio M6000 Motherboard Replacement: step 7, image 2 of 2
      • Place the flat end of the spudger underneath the digitizer connector and pry it up to disconnect it.
      Ask FixBot
    6. Kyocera Zio M6000 Motherboard Replacement: step 8, image 1 of 3 Kyocera Zio M6000 Motherboard Replacement: step 8, image 2 of 3 Kyocera Zio M6000 Motherboard Replacement: step 8, image 3 of 3
      • Remove the sticker to uncover the screws underneath.
      • Remove the six 1.59 mm screws using a Phillips 00 screwdriver.
      Ask FixBot
    7. Kyocera Zio M6000 Motherboard Replacement: step 9, image 1 of 3 Kyocera Zio M6000 Motherboard Replacement: step 9, image 2 of 3 Kyocera Zio M6000 Motherboard Replacement: step 9, image 3 of 3
      • Lift the bottom portion of the motherboard away from the front panel.
      • Do not forcefully pull the components apart as there is another connector on the underside of the motherboard attaching it to the panel.
      • Insert the flat end of the spudger in between the panel and motherboard to unfasten the connector.
      Ask FixBot
2 other people completed this guide.
Scott Nguyen
522 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 27
All Time: 562
