Kyocera Zio M6000 Battery Replacement
View statistics:
Past 24 Hours:
2
Past 7 Days:
21
Past 30 Days:
104
All Time:
735
Comments: 0
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 1
1 person has favorited (and subscribed to) this guide. Will you be next?
Time Required: 35 seconds - 1 minute
Difficulty: Easy
Introduction
Go to step 1 ↓
If battery power is draining too quickly, or if it is unable to hold a charge altogether, it's time to replace the battery. The task is simple and straightforward, with minimal tools required. Follow this guide to replace the battery for your Kyocera Zio M6000.
Tools
  • Spudger
    4.9
    1. Kyocera Zio M6000 Battery Replacement, Battery: step 1, image 1 of 2 Kyocera Zio M6000 Battery Replacement, Battery: step 1, image 2 of 2
      • Press down on the back of the phone, applying moderate pressure.
      • Slide the back casing down to separate it.
      Ask FixBot
    2. Kyocera Zio M6000 Battery Replacement: step 2, image 1 of 2 Kyocera Zio M6000 Battery Replacement: step 2, image 2 of 2
      • Remove the back casing to expose the battery.
      • Use a plastic spudger to lift the battery out using the battery's groove on its top left corner.
      Ask FixBot
Scott Nguyen
522 Reputation
3 Guides authored
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 21
Past 30 Days: 104
All Time: 735
