Kyocera QCP-2035 Microphone Replacement
  1. Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: step 1, image 1 of 3 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: step 1, image 2 of 3 Kyocera QCP-2035 Microphone Replacement, Remove Back Cover: step 1, image 3 of 3
    • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
    • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
    • In 5 mm it will stop sliding.
    Ask FixBot
  2. Kyocera QCP-2035 Microphone Replacement: step 2, image 1 of 3 Kyocera QCP-2035 Microphone Replacement: step 2, image 2 of 3 Kyocera QCP-2035 Microphone Replacement: step 2, image 3 of 3
    • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
    • Turn the phone over slowly. The battery will fall out on its own.
    Ask FixBot
  3. Kyocera QCP-2035 Microphone Replacement: step 3, image 1 of 3 Kyocera QCP-2035 Microphone Replacement: step 3, image 2 of 3 Kyocera QCP-2035 Microphone Replacement: step 3, image 3 of 3
    • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
    • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
    • Once the cover starts to part, keep separating until the top notches detach.
    Ask FixBot
  4. Kyocera QCP-2035 Microphone Replacement: step 4, image 1 of 3 Kyocera QCP-2035 Microphone Replacement: step 4, image 2 of 3 Kyocera QCP-2035 Microphone Replacement: step 4, image 3 of 3
    • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
    • Remove screws.
    • The white plastic face plate lifts right off, exposing the main board.
    Ask FixBot
  5. Kyocera QCP-2035 Microphone Replacement, Microphone: step 5, image 1 of 3 Kyocera QCP-2035 Microphone Replacement, Microphone: step 5, image 2 of 3 Kyocera QCP-2035 Microphone Replacement, Microphone: step 5, image 3 of 3
    Tool used on this step:
    Buy
    • Locate the microphone at the bottom left corner of the phone.
    • using tweezers, Lift the microphone straight out of the phone.
    Ask FixBot
cove
116 Reputation
1 Guide authored
USF Tampa, Team 5-3, Brown Winter 2015 Member of USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Members
18 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 18
All Time: 511
