Kyocera QCP-2035 Display Replacement
    1. Kyocera QCP-2035 Display Replacement, Remove Back Cover: step 1, image 1 of 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: step 1, image 2 of 3 Kyocera QCP-2035 Display Replacement, Remove Back Cover: step 1, image 3 of 3
      • When looking at the back of the phone, you will see a horizontal line and three raised segments of plastic in the form of a triangle.
      • Place thumb on top of the triangle and press into the phone while sliding your thumb towards the bottom of the phone.
      • In 5 mm it will stop sliding.
      Ask FixBot
    2. Kyocera QCP-2035 Display Replacement: step 2, image 1 of 3 Kyocera QCP-2035 Display Replacement: step 2, image 2 of 3 Kyocera QCP-2035 Display Replacement: step 2, image 3 of 3
      • Grab the bottom of the back cover with your other hand and pull the cover the rest of the way off.
      • Turn the phone over slowly. The battery will fall out on its own.
      Ask FixBot
    3. Kyocera QCP-2035 Display Replacement: step 3, image 1 of 3 Kyocera QCP-2035 Display Replacement: step 3, image 2 of 3 Kyocera QCP-2035 Display Replacement: step 3, image 3 of 3
      • Rotate the phone so the bottom is facing you. There is a small indent on the plastic face.
      • Using the tip of your fingernail or a spudger, pry the cover away from the rest of the phone.
      • Once the cover starts to part, keep separating until the top notches detach.
      Ask FixBot
    4. Kyocera QCP-2035 Display Replacement: step 4, image 1 of 3 Kyocera QCP-2035 Display Replacement: step 4, image 2 of 3 Kyocera QCP-2035 Display Replacement: step 4, image 3 of 3
      • With the cover plate separated, you will see (6) T6x11mm torx screws recessed in the white plastic.
      • Remove screws.
      • The white plastic face plate lifts right off, exposing the main board.
      Ask FixBot
    1. Kyocera QCP-2035 Display Replacement, Display: step 5, image 1 of 3 Kyocera QCP-2035 Display Replacement, Display: step 5, image 2 of 3 Kyocera QCP-2035 Display Replacement, Display: step 5, image 3 of 3
      Tool used on this step:
      Buy
      • Lift the display straight up, by either grabbing it on it's sides, or sliding a pair of tweezers between the screen and the main board.
      • There are four straight plastic pins on the underside corners of the screen that hold it in place.
      Ask FixBot
Scott Whitney
301 Reputation
3 Guides authored
USF Tampa, Team 5-3, Brown Winter 2015 Member of USF Tampa, Team 5-3, Brown Winter 2015
USFT-BROWN-W15S5G3
4 Members
72 Guides authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 15
All Time: 503
