Kyocera Oystr Screen Replacement
    1. Kyocera Oystr Screen Replacement, Removing the battery: step 1, image 1 of 3 Kyocera Oystr Screen Replacement, Removing the battery: step 1, image 2 of 3 Kyocera Oystr Screen Replacement, Removing the battery: step 1, image 3 of 3
      • Make sure the phone is turned off before disassembly.
      • Lift the bottom of the phone's back cover upwards, revealing the phone's battery housing.
      • Remove the battery from the casing. This is simply a precaution.
      • Turn the phone over, so that the front side is facing you. Open the device in preparation for the next step.
      Ask FixBot
    2. Kyocera Oystr Screen Replacement, Removing screws from screen: step 2, image 1 of 3 Kyocera Oystr Screen Replacement, Removing screws from screen: step 2, image 2 of 3 Kyocera Oystr Screen Replacement, Removing screws from screen: step 2, image 3 of 3
      • Peel the Virgin Mobile sticker off of the phone's screen to reveal two screws beneath it.
      • Use the Tri-Wing Y0 screwdriver to remove the two screws from the screen.
      Ask FixBot
    3. Kyocera Oystr Screen Replacement, Exposing internal components: step 3, image 1 of 3 Kyocera Oystr Screen Replacement, Exposing internal components: step 3, image 2 of 3 Kyocera Oystr Screen Replacement, Exposing internal components: step 3, image 3 of 3
      • Lift the plastic cover of the phone screen upwards with a plastic opening tool.
      • Remove the two screws from the metal cover.
      Ask FixBot
    4. Kyocera Oystr Screen Replacement, Removing metal cover: step 4, image 1 of 1
      • Remove the metal cover by lifting up and away from the device.
      Ask FixBot
    5. Kyocera Oystr Screen Replacement, Screen removal: step 5, image 1 of 3 Kyocera Oystr Screen Replacement, Screen removal: step 5, image 2 of 3 Kyocera Oystr Screen Replacement, Screen removal: step 5, image 3 of 3
      • Use the plastic opening tool to pry the phone's speakers up and away from the device. These speakers will dangle by the wires attached to the board.
      • Use your fingernail to detach the ribbon connecting the board to the screen.
      • Remove the damaged screen from the device.
      Ask FixBot
    6. Kyocera Oystr Screen Replacement, Completing the repair: step 6, image 1 of 1
      • Follow these steps in reverse order to replace Kyocera Oystr’s screen.
      Ask FixBot
David
24 Reputation
2 Guides authored
UW Stout, Team 5-7, Zhou Fall 2011 Member of UW Stout, Team 5-7, Zhou Fall 2011
UWSTOUT-ZHOU-F11S5G7
2 Members
24 Guides authored
2 Guide Comments
My screen goes blank for days, then shows. maybe for minutes of seconds. Do I need to replace the screen, or is there a control I can try to bring back the display? The phone is charged and rings. Yours is a wonderful website. Thank you.
Martha Carnahan mpc@netsync.net
Martha Carnahan - Reply Share
My screen goes blank for days, then appears, but only for minutes or seconds before it goes blank again. Do I need to replace the screen, or do you know if there a command which would solve the problem? The phone is charged and rings.
Past 24 Hours: 2
Past 7 Days: 5
Past 30 Days: 35
All Time: 2,822
