Kyocera Opal S14 Display Panel Replacement
  1. Kyocera Opal S14 Display Panel Replacement, Display Panel: step 1, image 1 of 1
    • Open the phone and power off the device.
    • Remove the SIM and SD cards.
    Ask FixBot
  2. Kyocera Opal S14 Display Panel Replacement: step 2, image 1 of 2 Kyocera Opal S14 Display Panel Replacement: step 2, image 2 of 2
    • Place the phone face-up with the display facing you.
    • Use a Phillips #00 to remove the four screws.
    Ask FixBot
  3. Kyocera Opal S14 Display Panel Replacement: step 3, image 1 of 2 Kyocera Opal S14 Display Panel Replacement: step 3, image 2 of 2
    • Starting at the corner, use the iFixit prying tool and gently insert it between the edge of the screen and the frame.
    • Apply gentle pressure and slowly pry the screen away.
    • Work your way around the edge of the device in a circular motion.
    • Make sure the screen is lifting evenly from all sides.
    Ask FixBot
  4. Kyocera Opal S14 Display Panel Replacement: step 4, image 1 of 2 Kyocera Opal S14 Display Panel Replacement: step 4, image 2 of 2
    • After working your way around the screen with the prying tool, gently lift the display panel from the frame.
    • As you lift the screen, you'll start to expose the bottom parts of the phone, be careful not to pull the screen away too quickly, as it is still connected to the device via cables.
    Ask FixBot
After successfully replacing the display, you'll need to reassemble the device by reversing the steps taken during disassembly. By doing this, you can easily reassemble your Kyocera Opal S14 and complete the display panel replacement.
Kimberlyn
31 Reputation
1 Guide authored
James Madison, Team 1-49, Allen Fall 2011 Member of James Madison, Team 1-49, Allen Fall 2011
JMU-ALLEN-F11S1G49
3 Members
12 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 5
Past 30 Days: 20
All Time: 1,286
