Kyocera Hydro Vibe Volume Button Replacement
    1. Kyocera Hydro Vibe Volume Button Replacement, Battery: step 1, image 1 of 1
      • Make sure that the device is turned off before beginning.
      • Look for a small indentation on the bottom of the phone.
      • Insert the plastic opening tool into the indentation and lift off the back casing.
      Ask FixBot
    2. Kyocera Hydro Vibe Volume Button Replacement: step 2, image 1 of 3 Kyocera Hydro Vibe Volume Button Replacement: step 2, image 2 of 3 Kyocera Hydro Vibe Volume Button Replacement: step 2, image 3 of 3
      • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
      • Place the plastic opening tool in the indentation and lift the battery out of the socket.
      Ask FixBot
    1. Kyocera Hydro Vibe Volume Button Replacement, Trim: step 3, image 1 of 1
      • Locate the screws holding the trim which are the four side screws on each corner.
      • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
      Ask FixBot
    2. Kyocera Hydro Vibe Volume Button Replacement: step 4, image 1 of 2 Kyocera Hydro Vibe Volume Button Replacement: step 4, image 2 of 2
      • Locate the clasps holding the trim in place.
      • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
      Ask FixBot
    3. Kyocera Hydro Vibe Volume Button Replacement: step 5, image 1 of 1
      • The trim is flimsy.
      • This is what the trim will look like once removed.
      Ask FixBot
    1. Kyocera Hydro Vibe Volume Button Replacement, Volume Button: step 6, image 1 of 3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: step 6, image 2 of 3 Kyocera Hydro Vibe Volume Button Replacement, Volume Button: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Once you have taken out the trim, the volume button will be easily removable.
      • Locate the volume button, if you are looking at the back of the phone (battery side) then it will be on the right side.
      • Take the tweezers and remove the button.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 21
Past 30 Days: 107
All Time: 753
