Kyocera Hydro Vibe Camera Button Replacement
    1. Kyocera Hydro Vibe Camera Button Replacement, Battery: step 1, image 1 of 1
      • Make sure that the device is turned off before beginning.
      • Look for a small indentation on the bottom of the phone.
      • Insert the plastic opening tool into the indentation and lift off the back casing.
      Ask FixBot
    2. Kyocera Hydro Vibe Camera Button Replacement: step 2, image 1 of 3 Kyocera Hydro Vibe Camera Button Replacement: step 2, image 2 of 3 Kyocera Hydro Vibe Camera Button Replacement: step 2, image 3 of 3
      • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
      • Place the plastic opening tool in the indentation and lift the battery out of the socket.
      Ask FixBot
    1. Kyocera Hydro Vibe Camera Button Replacement, Trim: step 3, image 1 of 1
      • Locate the screws holding the trim which are the four side screws on each corner.
      • Remove each screw with a Phillips screw driver #J00. The screws are 5mm Phillips.
      Ask FixBot
    2. Kyocera Hydro Vibe Camera Button Replacement: step 4, image 1 of 2 Kyocera Hydro Vibe Camera Button Replacement: step 4, image 2 of 2
      • Locate the clasps holding the trim in place.
      • You will need to insert the metal spudger through the bottom of the trim and slowly push upwards to release the clasps.
      Ask FixBot
    3. Kyocera Hydro Vibe Camera Button Replacement: step 5, image 1 of 1
      • The trim is flimsy.
      • This is what the trim will look like once removed.
      Ask FixBot
    1. Kyocera Hydro Vibe Camera Button Replacement, Camera Button: step 6, image 1 of 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: step 6, image 2 of 3 Kyocera Hydro Vibe Camera Button Replacement, Camera Button: step 6, image 3 of 3
      Tool used on this step:
      Buy
      • Now that you have taken apart the trim, the camera button should be easily removable.
      • Locate the camera button. When looking at the back side (battery side), the camera button will be on the left side.
      • Take the camera button out with tweezers.
      Ask FixBot
0 Guide Comments
Past 24 Hours: 3
Past 7 Days: 19
Past 30 Days: 98
All Time: 662
