Kyocera Hydro Vibe Battery Replacement
Views: 2.1K
View statistics:
Past 24 Hours:
2
Past 7 Days:
19
Past 30 Days:
96
All Time:
2,112
Comments: 0
Go to guide comments
Completed: 5
5 people have marked this guide "completed." Will you be next?
Favorites: 2
2 people have favorited (and subscribed to) this guide. Will you be next?
Time Required: 2 minutes
Difficulty: Very easy
Introduction
Go to step 1 ↓
This guide will teach you how to remove the back of the phone in order to gain access to the battery. Afterwards, we will instruct you on how to safely remove the battery from the device, and install a new one.
Tools
    1. Kyocera Hydro Vibe Battery Replacement, Battery: step 1, image 1 of 1
      • Make sure that the device is turned off before beginning.
      • Look for a small indentation on the bottom of the phone.
      • Insert the plastic opening tool into the indentation and lift off the back casing.
      Ask FixBot
    2. Kyocera Hydro Vibe Battery Replacement: step 2, image 1 of 3 Kyocera Hydro Vibe Battery Replacement: step 2, image 2 of 3 Kyocera Hydro Vibe Battery Replacement: step 2, image 3 of 3
      • The large white component is the battery. Look for a small indentation under the arrow that says "LIFT."
      • Place the plastic opening tool in the indentation and lift the battery out of the socket.
      Ask FixBot
5 other people completed this guide.
0 Guide Comments
Past 24 Hours: 2
Past 7 Days: 19
Past 30 Days: 96
All Time: 2,112
