Up to 20% off select tools
Kyocera Event Rear Assembly Replacement
Views: 1.3K
View statistics:
Past 24 Hours:
0
Past 7 Days:
6
Past 30 Days:
28
All Time:
1,346
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 5 - 10 minutes
Difficulty: Moderate
Tools
Introduction
Go to step 1 ↓
In order to reach the motherboard of the mobile phone, the back assembly needs to be removed.
    1. Kyocera Event Rear Assembly Replacement, Battery: step 1, image 1 of 3 Kyocera Event Rear Assembly Replacement, Battery: step 1, image 2 of 3 Kyocera Event Rear Assembly Replacement, Battery: step 1, image 3 of 3
      • Locate the small notch on the bottom right side of the phone.
      • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
      • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
      Ask FixBot
    2. Kyocera Event Rear Assembly Replacement: step 2, image 1 of 1
      • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
      • The plastic prying tool can be used to help remove the battery.
      Ask FixBot
    1. Kyocera Event Rear Assembly Replacement, Locate the SIM card: step 3, image 1 of 1
      • The SIM card slot can be seen in the middle left of the photograph.
      Ask FixBot
    2. Kyocera Event Rear Assembly Replacement, Open slot and remove card: step 4, image 1 of 2 Kyocera Event Rear Assembly Replacement, Open slot and remove card: step 4, image 2 of 2
      • The SD card slot can be opened and closed, as depicted by the tool.
      • The SD card itself slides into and out of the metal cover.
      • The gold tipped tines are what read the SD card along its bottom.
      Ask FixBot
    1. Kyocera Event Rear Assembly Replacement, Remove the screws.: step 5, image 1 of 2 Kyocera Event Rear Assembly Replacement, Remove the screws.: step 5, image 2 of 2
      • Remove seven of the 4.9mm tri-head screws. Keep them in a secure location.
      Ask FixBot
    2. Kyocera Event Rear Assembly Replacement, Remove the back assembly: step 6, image 1 of 3 Kyocera Event Rear Assembly Replacement, Remove the back assembly: step 6, image 2 of 3 Kyocera Event Rear Assembly Replacement, Remove the back assembly: step 6, image 3 of 3
      • Pry the back assembly away from the body on all four sides of the phone.
      • Start prying at the top and work around.
      • Remove the buttons for the volume and power-this will allow for easier disassembly.
      • The back assembly is firmly attached to the body of the phone so removing it will require some force.
      Ask FixBot
Author
with
Philip
7 Reputation
1 Guide authored
0 Guide Comments
Past 24 Hours: 0
Past 7 Days: 6
Past 30 Days: 28
All Time: 1,346
