Up to 20% off select tools
Kyocera Event MicroSD Card Replacement
Views: 3.7K
View statistics:
Past 24 Hours:
Past 7 Days:
2
Past 30 Days:
27
All Time:
3,670
Comments: 4
4 guide comments.
Go to guide comments
Completed: 1
1 person has marked this guide "completed." Will you be next?
Favorites: 0
Time Required: No estimate
Difficulty: Moderate
Introduction
Go to step 1 ↓
The optional microSD memory card expands your phone's available storage so you can save more images, videos, music, documents, and voice data. If you need more storage or if you suspect your card is faulty, follow this guide to swap it out.
    1. Kyocera Event MicroSD Card Replacement, Battery: step 1, image 1 of 3 Kyocera Event MicroSD Card Replacement, Battery: step 1, image 2 of 3 Kyocera Event MicroSD Card Replacement, Battery: step 1, image 3 of 3
      • Locate the small notch on the bottom right side of the phone.
      • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
      • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
      Ask FixBot
    2. Kyocera Event MicroSD Card Replacement: step 2, image 1 of 1
      • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
      • The plastic prying tool can be used to help remove the battery.
      Ask FixBot
    1. Kyocera Event MicroSD Card Replacement, Locate the SIM card: step 3, image 1 of 1
      • The SIM card slot can be seen in the middle left of the photograph.
      Ask FixBot
    2. Kyocera Event MicroSD Card Replacement, Open slot and remove card: step 4, image 1 of 2 Kyocera Event MicroSD Card Replacement, Open slot and remove card: step 4, image 2 of 2
      • The SD card slot can be opened and closed, as depicted by the tool.
      • The SD card itself slides into and out of the metal cover.
      • The gold tipped tines are what read the SD card along its bottom.
      Ask FixBot
Author
with
graysonmensah
22 Reputation
1 Guide authored
4 Guide Comments
That's the micro SD slot. That's not for a SIM card.
Carl Jr - Reply Share
What if there's no metal cover?
Michael ansley - Reply Share
That's for the sd card not the sim card
gasparesparza9 - Reply Share
Where can I insert the sim card
pauline cynthia joe - Reply Share
Past 24 Hours: 1
Past 7 Days: 2
Past 30 Days: 27
All Time: 3,670
