Up to 20% off select tools
Kyocera Event Battery Replacement
Views: 4.7K
View statistics:
Past 24 Hours:
4
Past 7 Days:
6
Past 30 Days:
22
All Time:
4,662
Comments: 0
Go to guide comments
Completed: 2
2 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 1 - 5 minutes
Difficulty: Easy
Tools
Introduction
Go to step 1 ↓
A battery is essential to turn on the phone. In this guide you will learn how to remove the battery in a Kyocera Event and put another battery to Kyocera Event efficiently.
    1. Kyocera Event Battery Replacement, Battery: step 1, image 1 of 3 Kyocera Event Battery Replacement, Battery: step 1, image 2 of 3 Kyocera Event Battery Replacement, Battery: step 1, image 3 of 3
      • Locate the small notch on the bottom right side of the phone.
      • To remove the cover, hook your thumb or fingernail into the slot. Then, gently lift the cover up and off.
      • The back cover may flex slightly as you remove it. This is normal, but avoid applying excessive force.
      Ask FixBot
    2. Kyocera Event Battery Replacement: step 2, image 1 of 1
      • Locate the small notch below the battery. You may see a white plastic notch sticking out of this space; if so, grasp that tab to pull the battery out of its compartment. If you do not see a white plastic tab, then place your fingernail in the notch and pull upward to release the battery from its compartment.
      • The plastic prying tool can be used to help remove the battery.
      Ask FixBot
2 other people completed this guide.
Author
with
Jen Michaels
22 Reputation
1 Guide authored
Ohio State, Team 1-1, Michaels Fall 2013 Member of Ohio State, Team 1-1, Michaels Fall 2013
OSU-MICHAELS-F13S1G1
1 Member
12 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 6
Past 30 Days: 22
All Time: 4,662
