Up to 20% off select tools
Kyocera Echo Camera Replacement
View statistics:
Past 24 Hours:
4
Past 7 Days:
16
Past 30 Days:
68
All Time:
742
Comments: 0
Go to guide comments
Completed: 0
Favorites: 0
Time Required: 25 - 30 minutes
Difficulty: Moderate
Featured Student Guide
This guide has been the hard work of our awesome students and is found to be exceptionally cool by the iFixit staff.
Tools
Introduction
Go to step 1 ↓
Use this guide if you need to replace the camera in your Kyocera Echo smartphone. This guide should be taken slowly, as the general circuit board is glued to the screen. Removing this with the opening tool is easy to do without destroying it, as long as the user is careful.
    1. Kyocera Echo Camera Replacement, Battery: step 1, image 1 of 1
      • Orient the phone so that the screen is face down.
      • Place one or both thumbs near the small arrow at the bottom of the phone and firmly push the cover up.
      Ask FixBot
    2. Kyocera Echo Camera Replacement: step 2, image 1 of 1
      • Pull up on the back cover and lift the top to separate it from the phone.
      Ask FixBot
    3. Kyocera Echo Camera Replacement: step 3, image 1 of 1
      • Pull the battery out of the device with a thin object such as your nail or credit card.
      Ask FixBot
    1. Kyocera Echo Camera Replacement, Camera: step 4, image 1 of 1
      • Unscrew four 4.3mm Phillips #000 screws.
      Ask FixBot
    2. Kyocera Echo Camera Replacement: step 5, image 1 of 1
      • Unscrew two 4.8mm Y000 screws.
      Ask FixBot
    3. Kyocera Echo Camera Replacement: step 6, image 1 of 2 Kyocera Echo Camera Replacement: step 6, image 2 of 2
      • Wedge a plastic opening tool under the black outer casing of the phone. Push the plastic opening tool down and outward while rotating the phone to pry the black outer casing off.
      • Do not apply too much pressure to the outer casing, as it could damage internal components.
      Ask FixBot
    4. Kyocera Echo Camera Replacement: step 7, image 1 of 2 Kyocera Echo Camera Replacement: step 7, image 2 of 2
      • Wedge a plastic opening tool under the bottom of the circuit board and push upward to separate the circuit board from the back of the phone.
      • Be careful to not break the circuit board as it is connected to the hinge.
      Ask FixBot
    5. Kyocera Echo Camera Replacement: step 8, image 1 of 1
      • Push the camera gently out of its housing towards the side of the circuit board it is connected at to dislodge it.
      Ask FixBot
    6. Kyocera Echo Camera Replacement: step 9, image 1 of 1
      • Grasp and pull up on the 32 pin connector attached to the circuit board to remove the camera.
      Ask FixBot
Author
with
Alex Kinstedt
483 Reputation
4 Guides authored
IUPUI, Team S2-G6, Baechle Fall 2018 Member of IUPUI, Team S2-G6, Baechle Fall 2018
IUPUI-BAECHLE-F18S2G6
3 Members
48 Guides authored
0 Guide Comments
Past 24 Hours: 4
Past 7 Days: 16
Past 30 Days: 68
All Time: 742
