Kyocera DuraForce Pro Battery Replacement
Views: 5.5K
View statistics:
Past 24 Hours:
Past 7 Days:
14
Past 30 Days:
76
All Time:
5,500
Comments: 1
1 comment on steps.
Completed: 7
7 people have marked this guide "completed." Will you be next?
Favorites: 0
Time Required: 15 minutes
Difficulty: Moderate
Better Introduction
Improve this guide by completing or revising its introduction.
Tools
    1. Kyocera DuraForce Pro Battery Replacement, Battery: step 1, image 1 of 3 Kyocera DuraForce Pro Battery Replacement, Battery: step 1, image 2 of 3 Kyocera DuraForce Pro Battery Replacement, Battery: step 1, image 3 of 3
      • Be sure the device is turned off.
      • Flip the phone onto its backside.
      • Remove the back cover by using a plastic opening tool.
      Ask FixBot
    2. Kyocera DuraForce Pro Battery Replacement: step 2, image 1 of 3 Kyocera DuraForce Pro Battery Replacement: step 2, image 2 of 3 Kyocera DuraForce Pro Battery Replacement: step 2, image 3 of 3
      • Remove the eight screws with a JIS #0 screwdriver.
      Ask FixBot
    3. Kyocera DuraForce Pro Battery Replacement: step 3, image 1 of 3 Kyocera DuraForce Pro Battery Replacement: step 3, image 2 of 3 Kyocera DuraForce Pro Battery Replacement: step 3, image 3 of 3
      • Once the back cover is removed, the (6) buttons along the side are going to fall out of place.
      Ask FixBot
    4. Kyocera DuraForce Pro Battery Replacement: step 4, image 1 of 3 Kyocera DuraForce Pro Battery Replacement: step 4, image 2 of 3 Kyocera DuraForce Pro Battery Replacement: step 4, image 3 of 3
      Tool used on this step:
      Buy
      • Using the plastic opening tool from earlier, lift the battery out by wedging it along the edge.
      • Using tweezers, unlock the ribbon cable port and lightly pull the cable upwards until it becomes unplugged.
      Ask FixBot
7 other people completed this guide.
Dylan Ulbricht
735 Reputation
5 Guides authored
0 Guide Comments
Past 24 Hours: 1
Past 7 Days: 14
Past 30 Days: 76
All Time: 5,500
